Sunba 636 PTZ Control
Posted: Sat Sep 30, 2023 2:46 am
I have two Sunba Cameras. I am attempting to get one to be controlled by ZM from the monitor. I have the Control Left Right Up and Down as well as Diagonal working fine, however, my Focus and Zoom are not working. The Zoom seems to not be controllable. It will only zoom all the way out or all the way in. Nothing in between. Focus just does not seem to work at all. This camera also has Patrol as a feature that is controllable, id like to get that into this as well. Thanks in advance!
Update:I found the piece of code that was broken for the Zoom to Autostop. Ironically, it is in the portion of the Autostop code Msg: that states "# Reported to not work, so superceded by the cmd above
<Zoom>false" Changing to "<Zoom>true" fixed my issue. I can now count on the setting in the Control for the monitor to auto timeout whatever I have it set at.
