wanted to add "nginx configuration" to https://wiki.zoneminder.com/Debian_12_B ... er_1.36.33, but i can not login. Maybe i am too stupid for that
This is nearby the same conf file as from nginx with Bullseye, just two little differences:
it has to be "/zm/cgi-bin" and not "/cgi-bin"
it has to be php-8.2 instead if php-7.4
Maybe someone wants to add this into the wiki?
location /zm/cgi-bin {
auth_basic off;
alias /usr/lib/zoneminder/cgi-bin;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $request_filename;
fastcgi_param HTTP_PROXY "";
fastcgi_pass unix:/var/run/fcgiwrap.socket;
location /zm/cache {
auth_basic off;
alias /var/cache/zoneminder/cache;
location ~ /zm/api/(css|img|ico) {
auth_basic off;
rewrite ^/zm/api(.+)$ /api/app/webroot/$1 break;
try_files $uri $uri/ =404;
location /zm {
auth_basic off;
alias /usr/share/zoneminder/www;
try_files $uri $uri/ /index.php?$args =404;
location /zm/api {
auth_basic off;
rewrite ^/zm/api(.+)$ /zm/api/app/webroot/index.php?p=$1 last;
location ~ \.php$ {
auth_basic off;
fastcgi_index index.php;
fastcgi_pass unix:/var/run/php/php8.2-fpm.sock;
Regardes
