I'm trying to setup a Zosi camera (I know - it's trash) to stream snapshot JPG files into ZoneMinder.
If I go to this URL using Edge, it downloads a snapshot.jpg file:http://zm:zm@192.168.1.55/snapshot.jpg? ... =zm&strm=0
However, I have set this up in ZM using Remote source, and following:
BUT - it doesn't work. A packet capture shows the HTTP interaction seems to work, but then just breaks down with ZM sending a TCP reset:
A similar packet capture from my connection with EDGE looks really similar, but with more data:
How do I get ZM to download this JPG file and use it as frames?
Zosi camera snapshot JPG files into ZM
Re: Zosi camera snapshot JPG files into ZM
if it helps, the log for this camera in the /var/log/zoneminder/ directory states:
10/21/23 22:26:27.829859 zmc_m12[272229].ERR-zm_remote_camera_http.cpp/827 [Unrecognised content type 'application/octet-stream']
10/21/23 22:26:27.829967 zmc_m12[272229].ERR-zm_remote_camera_http.cpp/1087 [Unable to get response, disconnecting]
10/21/23 22:26:27.830427 zmc_m12[272229].ERR-zmc.cpp/305 [Failed to capture image from monitor 12 Front Door (1/1)]
Looks like it doesn't like the type application/octet-stream.
Uhm, why? I don't think zm can do that - it wants a stream, as you can see.
BTW, usually it's better to leave colorspace at 32, as counterintuitive as that is.
I don't disagree, the cameras probably need replacement. However, I was able to get FFMPEG to form a stream from the JPG files using the following command:
ffmpeg -stream_loop -1 -framerate 5 -i "http://zm:zm@192.168.1.55/snapshot.jpg? ... =zm&strm=0" output.mp4
If I run that command, it does make an MP4 video using the JPG files, which it grabs 5/second. However, I can't figure out how to give the FFMPEG source in ZM the '-stream_loop -1' and '-framerate 5'. I have tried putting them as options using FFMPEG source type, but in the log it says it cannot parse the options.
Any clues in the ffmpeg log?
If not you can try upping debug output. It does require a restart for the debug to start.
Are you sure this camera doesn't support rtsp?
Anyways... I could add support for application/octet-stream.... but we would just be assuming that it is a jpeg.. could be anything...
Please update to 1.37 latest build and give it a try. I added support for application/octet-stream
