Added a camera now have odd errors in log.
Seanc18
Post by Seanc18 »
I got a pts Wi-Fi camera streaming to zoneminder but I have no ptz control and I am getting stuff In my log I’m not sure what to do with it.
I attached an export table of the logs from zoneminder
tableExport.txt
(59.22 KiB) Downloaded 71 times
Re: Added a camera now have odd errors in log.
Is this your first camera?
If so please show your zm camera settings. Also, how did you install? On what OS? Looks like you might have incorrect permissions or other problem.
First, 1.36.12 is very old. You should be at 1.36.33.
You appear to have turn on hwaccel encoding... you should probably just use passthrough.
Seanc18
Post by Seanc18 »
dougmccrary wrote: Sun Oct 22, 2023 8:12 am Is this your first camera?
im at 1.36.32 now
i got 1 camera working with stream and ptz.
Now im trying to install a Boavision Camera it streams fine but i cannot get the PTZ to stop moving
here are my settings and logs
10/25/2023 20:44:04.403145 zmcontrol_3[1033202].DB1 [main:165] [$VAR1 = {
          'command' => 'moveStop',
          'tiltspeed' => '3',
          'panspeed' => '3'
10/25/2023 20:44:04.403186 zmcontrol_3[1033202].DB1 [ZoneMinder::Control::onvif:521] [Move Stop]
10/25/2023 20:44:04.403217 zmcontrol_3[1033202].DB1 [ZoneMinder::Control:237] [/11/onvif[9]]
10/25/2023 20:44:04.413831 zmcontrol_3[1033202].ERR [ZoneMinder::Control::onvif:191] [After sending PTZ command, camera returned the following error:'400 Bad Request'
10/25/23, 11:57:11 PM CDT	zmcontrol_3		1364735	ERR	After sending PTZ command, camera returned the following error:'400 Bad Request'MSG: /onvif/ptz_servicetruetrue Response:s:Receiverter:ActionNotSupportedAction Not Implemented	zmcontrol.pl	-
10/25/23, 11:57:11 PM CDT	zmcontrol_3		1364735	ERR	After sending PTZ command, camera returned the following error:'400 Bad Request'MSG: /onvif/ptz_service true false Response:s:Receiverter:ActionNotSupportedAction Not Implemented
Seanc18
Post by Seanc18 »
also this is the camera im having issues with
https://www.amazon.com/dp/B08J158TVV?psc=1&ref=ppx_yo2ov_dt_b_product_details
