Boavision onvif PTZ camera-help please
Seanc18
Post by Seanc18 »
im adding a boavision camera to the server and for the life of me i cannot get the PTZ to stop moving also the 4X zoom doesnt work at all.
stream works great.
Monitor Source path is set to
rtsp://xxxxx:xxxxx@192.168.69.9/11
onvif tab is set to
192.168.69.9/11
not sure its even doing anything.
10/25/23, 10:24:09 PM CDT	zmcontrol_3		1312712	ERR	After sending PTZ command, camera returned the following error:'400 Bad Request'MSG: admin Q1ytLMvOmpQhQiG+Yys+Y7TmcPw= Wk5lSENQcjNUQzgxRUV0cFgwSkc= 2023-10-26T03:24:09Z 000truetrue Response:s:Receiverter:ActionNotSupportedAction Not Implemented	zmcontrol.pl	-
10/25/23, 10:24:09 PM CDT	zmcontrol_3		1312712	ERR	After sending PTZ command, camera returned the following error:'400 Bad Request'MSG: admin sKbnFu5naecYzKi96qcdmIMgi4s= bEZtQ21tdDVqS1BYN2MyUm1rbFI= 2023-10-26T03:24:09Z 000 false true Response:s:Receiverter:ActionNotSupportedAction Not Implemented	zmcontrol.pl	-
10/25/23, 10:24:09 PM CDT	zmcontrol_3		1312712	ERR	After sending PTZ command, camera returned the following error:'400 Bad Request'MSG: admin ZnZFHUX/yVF8GnjzyeGOOJCWxe4= OXFtM0FLWjdEbTNFeTI5WDBScHY= 2023-10-26T03:24:08Z 000truetrue Response:s:Receiverter:ActionNotSupportedAction Not Implemented	zmcontrol.pl	-
10/25/23, 10:24:08 PM CDT	zmcontrol_3		1312712	ERR	After sending PTZ command, camera returned the following error:'400 Bad Request'MSG: admin eIhL4qS4lgPkcc8CpSratafnx6M= R3dxZ1JyVXJ2OW9oWER2Y3FjYjQ= 2023-10-26T03:24:08Z 000 false true Response:s:Receiverter:ActionNotSupportedAction Not Implemented	zmcontrol.pl	-
10/25/23, 10:24:08 PM CDT	zmcontrol_3		1312712	ERR	After sending PTZ command, camera returned the following error:'400 Bad Request'MSG: admin q6DVqU0alKBgMcYRkL/9x1oS7yA= bkxlcGtjZTNmRzY4TlBEZEpjZmQ= 2023-10-26T03:24:08Z 000truetrue Response:s:Receiverter:ActionNotSupportedAction Not Implemented	zmcontrol.pl	-
10/25/23, 10:24:08 PM CDT	zmcontrol_3		1312712	ERR	After sending PTZ command, camera returned the following error:'400 Bad Request'MSG: admin FWq6K8dzTyxN2VIt9rGrNRv7WYA= QkJHMFVRVk05V1E2U05lZ0dWaEI= 2023-10-26T03:24:08Z 000 false true Response:s:Receiverter:ActionNotSupportedAction Not Implemented	zmcontrol.pl	-
10/25/23, 10:24:07 PM CDT	zmcontrol_3		1312712	ERR	Zoom Stop not implemented	zmcontrol.pl	-
10/25/23, 10:24:07 PM CDT	zmcontrol_3		1312712	ERR	After sending PTZ command, camera returned the following error:'400 Bad Request'MSG: admin si1XkYw6D1xWl4fLTjIn3T2krn8= dXBSbmZBdnI2MlR5NTNpVnZJVUM= 2023-10-26T03:24:07Z 000 false true Response:s:Receiverter:ActionNotSupportedAction Not Implemented	zmcontrol.pl
Re: Boavision onvif PTZ camera-help please
Just something to try - make /11 /1
see if it matters.
Seanc18
Post by Seanc18 »
dougmccrary wrote: Thu Oct 26, 2023 9:44 am Just something to try - make /11 /1
see if it matters.
didnt help.
this is from debug log
10/25/2023 20:44:04.403145 zmcontrol_3[1033202].DB1 [main:165] [$VAR1 = {
          'command' => 'moveStop',
          'tiltspeed' => '3',
          'panspeed' => '3'
10/25/2023 20:44:04.403186 zmcontrol_3[1033202].DB1 [ZoneMinder::Control::onvif:521] [Move Stop]
10/25/2023 20:44:04.403217 zmcontrol_3[1033202].DB1 [ZoneMinder::Control:237] [/11/onvif[9]]
10/25/2023 20:44:04.413831 zmcontrol_3[1033202].ERR [ZoneMinder::Control::onvif:191] [After sending PTZ command, camera returned the following error:'400 Bad Request'
10/25/23, 11:57:11 PM CDT	zmcontrol_3		1364735	ERR	After sending PTZ command, camera returned the following error:'400 Bad Request'MSG: /onvif/ptz_servicetruetrue Response:s:Receiverter:ActionNotSupportedAction Not Implemented	zmcontrol.pl	-
10/25/23, 11:57:11 PM CDT	zmcontrol_3		1364735	ERR	After sending PTZ command, camera returned the following error:'400 Bad Request'MSG: /onvif/ptz_service true false Response:s:Receiverter:ActionNotSupportedAction Not Implemented
Seanc18
Post by Seanc18 »
Screenshot 2023-10-26 at 20-54-02 ZM - Monitor - Garage.png (37.99 KiB) Viewed 13250 times
That's a starting point that works for me.
I've never before got it to work at all, cuz I don't much care.
Seanc18
Post by Seanc18 »
Actually got the Boavison PTZ camera working working and the ptz stopping and moving correctly
Purview: Check type No check
Have you tried setting this onvif camera setting to check?
