Camera stream not running
MyBrainIsAStrainer
Post by MyBrainIsAStrainer »
Hello!
I'm trying to run ZoneMinder on a Raspberry Pi400 with a Reolink RLC-842A camera. But no matter what I do, I cannot get ZoneMinder to show the camera as running.
The camera supports ONVIF, and when I use the probe function within ZM, it creates a setup that looks ok to me. The streaming URL is:
rtsp://user:pass@192.168.0.210:554/
I also tried rtsp://user:pass@192.168.0.210:554/h264Preview_01_main, which some websites suggest as the correct path. But it doesn't help either.
The source type is auto-set to ffmpeg but when I use "Remote", it also doesn't work. Same goes for setting the method in the source tab (TCP, UDP, UDP Multicast, HTTP)
I can use IP CENTCOM on a Windows machine to display the stream. I can use Frigate inside a docker container on the Pi400 to display the stream.
# grep path /opt/frigate/config.yml
        - path: rtsp://admin:admin1234@192.168.0.210:554/ #The Stream you want to monitor
It's just ZoneMinder which refuses to actually connect to the camera. What am I doing wrong?
Raspberry PiOS (Debian Bookworm)
ZoneMinder 1.36.33 (from Debian packages)
Camera firmware 3.1.0.1643_22122317
Re: Camera stream not running
Does vlc see anything with this?
Try stuff in vlc (quicker) and use what works in zm.
Also, this may provide a fix - iSpy works same as zm at this level.
https://support.reolink.com/hc/en-us/ar ... a-to-Ispy/
Try it on the commandline of the Pi.
Look at logs, they will likely tell you what is wrong.
MyBrainIsAStrainer
Thanks for the replies.
No, VLC also does not seem to work:
$ vlc "rtsp://user:pass@192.168.0.210:554/"
VLC media player 3.0.16 Vetinari (revision 3.0.13-8-g41878ff4f2)
[000055c6b0cbf430] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[00007f17a0001630] satip stream error: Failed to setup RTSP session
[00007f17a0001590] satip stream error: Failed to setup RTSP session
[00007f17a0001410] satip stream error: Failed to setup RTSP session
[00007f17a0003600] satip stream error: Failed to setup RTSP session
[00007f17a4001820] satip stream error: Failed to setup RTSP session
But like I wrote earlier: Frigate works. I also managed to get it to work with MotionEye. The CPU load is little bit too high for my taste when you add a second camera. But it does work.
The logs don't show anything. All I see is what is logged during the ONVIF probe. But nothing related to the stream itself.
Date/Time,Component,Server,PID,Level,Message,File,Line
"10/28/23, 3:48:25 PM UTC",web_php,,8075,WAR,"Array(    [0] => 001, Profile001_SubStream, H264, 640, 360, 10, RTP-Multicast, rtsp://192.168.0.210:554/h264Preview_01_sub    [1] => 001    [2] => Profile001_SubStream    [3] => H264    [4] => 640    [5] => 360    [6] => 10    [7] => RTP-Multicast    [8] => rtsp://192.168.0.210:554/h264Preview_01_sub)",/usr/share/zoneminder/www/skins/classic/views/onvifprobe.php,106
"10/28/23, 3:48:25 PM UTC",web_php,,8075,WAR,"Array(    [0] => 001, Profile001_SubStream, H264, 640, 360, 10, RTP-Unicast, rtsp://192.168.0.210:554/h264Preview_01_sub    [1] => 001    [2] => Profile001_SubStream    [3] => H264    [4] => 640    [5] => 360    [6] => 10    [7] => RTP-Unicast    [8] => rtsp://192.168.0.210:554/h264Preview_01_sub)",/usr/share/zoneminder/www/skins/classic/views/onvifprobe.php,106
"10/28/23, 3:48:25 PM UTC",web_php,,8075,WAR,"Array(    [0] => 000, Profile000_MainStream, H264, 3840, 2160, 25, RTP-Multicast, rtsp://192.168.0.210:554/    [1] => 000    [2] => Profile000_MainStream    [3] => H264    [4] => 3840    [5] => 2160    [6] => 25    [7] => RTP-Multicast    [8] => rtsp://192.168.0.210:554/)",/usr/share/zoneminder/www/skins/classic/views/onvifprobe.php,106
"10/28/23, 3:48:25 PM UTC",web_php,,8075,WAR,"Array(    [0] => 000, Profile000_MainStream, H264, 3840, 2160, 25, RTP-Unicast, rtsp://192.168.0.210:554/    [1] => 000    [2] => Profile000_MainStream    [3] => H264    [4] => 3840    [5] => 2160    [6] => 25    [7] => RTP-Unicast    [8] => rtsp://192.168.0.210:554/)",/usr/share/zoneminder/www/skins/classic/views/onvifprobe.php,106
I tested it in a VM on my desktop, and it also didn't work there. So I think I can rule out any problems regarding the ARM architecture of the Pi4.
And, just be sure I mentioned it: RTSP is enabled in the camera settings (otherwise, it wouldn't have worked with the other programs), and the port is set to 554.
Isn’t Frigate run in a container?
MyBrainIsAStrainer
Magic919 wrote: Sat Oct 28, 2023 7:25 pm Isn’t Frigate run in a container?
Yes. It can still capture and display the stream of the camera.
Which points to the problem being with the software on the Pi.
MyBrainIsAStrainer
Magic919 wrote: Sun Oct 29, 2023 7:52 am Which points to the problem being with the software on the Pi.
I'm not so sure about that.
Reasons:
  • It not only works with Frigate inside a container but also with a natively installed MotionEye. If the native environment had some kind of issue, why isn't Motion affected?
  • I've also tried to run ZoneMinder in a VM with a fresh install of Debian 12.2 on my desktop. Still didn't work. Are there known issues with vanilla Debian 12 on amd64 platforms?
  • To further test the hypothesis, I installed docker in the VM and ran zoneminderhq/zoneminder:latest-ubuntu18.04. It has the same issue. So even inside a docker container, ZM still refuses to display the camera stream.
Ubuntu is probably a better match for ZM.
Perhaps try the rtmp stream. rtmp://ip adress/bcs/channel0_main.bcs?channel=0&stream=0&user=usenam&password=pass
This from onvif probe:
I think you fail to specify a stream, e.g.,
I'm pretty sure using the above would work in vlc.
