1.37.47~20231102142631-
The time change didn't look good...just realized that's what it was when it got to 0200 again.
Didn't seem to bother 1.36 though.
Re: 1.37.47~20231102142631-
Is this available?what do you mean the time change didnt look good? I had no issues here
Sorry. yes it's available.
I should have elaborated.
During the time overlap from 0200 to 0100 back to 0200, the console said all cameras were offline.
It wasn't until the second 0200 that it went back to normal.
Meanwhile my 1.36 appeared normal on the console. Just freaked me out for a while :shock:
Now, looking some more, there's this
Screenshot 2023-11-06 at 01-29-24 ZMX - Events.png (86.45 KiB) Viewed 15167 times
There is an extra hour of folders to account for the missing times, but I'm not finding which ones, as the IDs seem to be in order, as if those files don't exist. :( Turns out it's the same - missing hour - on 1.36, so this has apparently been overlooked for a while.
erona89
Post by erona89 »
Daylight Saving Time (DST) ends on the first Sunday in November, which means that clocks fall back one hour at 2:00 AM on that day. This can make it seem like time has somehow "disappeared."
geometry dash world
Right. So what if something happens at 0130 PST?
Time should go ...0159.59PDT...0100PST...0200PST, should it not? Probably not easy to fix, but still.
