Page 1 of 2
New zmNinja release for Android
Posted: Wed Nov 08, 2023 11:21 pm
by iconnor
We have a new version (1.7.000) uploaded to internal testing
If you are interested in early access, say so, provide your email address (that you log into Play with) and we will add you.
Re: New zmNinja release for Android
Posted: Fri Nov 17, 2023 5:16 pm
by iconnor
The new release is now generally available.
Posted: Wed Nov 22, 2023 6:01 pm
by Caveman
Kudos for the update! Unfortunately, Android 14 is now running some of our phones so I can't load zmNinja on my Pixel.
Hopefully the next release of zmNinja isn't too far out and the toolchain is updated to build for 14.
Posted: Wed Nov 22, 2023 6:02 pm
by iconnor
1.7 release works on android 14.
There are issues with notifications though. We are working on it.
Posted: Wed Nov 22, 2023 8:24 pm
by Caveman
Ah, you are correct. I don't know what the issue was when I tried it last night, Play said not compatible with my phone.
I've installed it now and will be giving it a try when I finish configuring ZM after my cameras get here.
Thanks!
Posted: Thu Nov 23, 2023 3:13 pm
by iconnor
Latest release 1.7.002 should fix notifications
Posted: Sat Nov 25, 2023 12:16 pm
by bodgit
Hi, Just downloaded zmNinja from the Play Store to my phone and it is showing Version 1.6.009 not the latest 1.7.002
Any ideas ?
Thanks in advance.
Posted: Sat Nov 25, 2023 3:01 pm
by iconnor
You downloaded zmninja-pro.
Posted: Sat Nov 25, 2023 5:21 pm
by bodgit
Thank you.
Posted: Sun Nov 26, 2023 5:15 am
by Sean298
I've installed the new version but I don't have any montage or images available, the older app has worked decent.
Posted: Sun Nov 26, 2023 4:33 pm
by iconnor
Double check your config. Montage and images work fine for us. We are aware of problems with the wizard and expert mode of configuring it.
Posted: Mon Nov 27, 2023 2:31 am
by Sean298
Hm, my config shows the same paths as it did before, I'm not sure.
Thanks for all the effort you've put into these projects.
Posted: Tue Nov 28, 2023 8:10 pm
by iconnor
There are new desktop packages available at github now.
https://github.com/ZoneMinder/zmNinja/r ... g/v1.7.002
Posted: Wed Nov 29, 2023 12:11 am
by pepex7
Gracias..!!
Posted: Fri Dec 08, 2023 12:04 pm
by alabamatoy
Play store shows me zmninja for $4.99 and zmninja pro as installed (I've had the last old reliable 1.6 installed forever it seems).
Is the $4.99 version the new update?
Confused....
BTW thanks so much for your tireless work on ZM.
