New zmtrigger events creates a new event but continues an old.
It's hard to explain, but every time I have a new event created by "3|on+5|5|Motion|Motion|Motion" I get the new event, but I also get a continuation of a old recording. As you can see every other snapshot is just some original that keeps growing. Cameras are set to nodect and only record with a trigger.
- Screenshot 2023-12-08 at 12.22.42 PM.png (928.13 KiB) Viewed 6917 times
Re: New zmtrigger events creates a new event but continues an old.
Regarding event 503 you can see it exceeded desired section length:
12/08/23 11:11:13.719995 zmc_m3[16880].INF-zm_monitor.cpp/1983 [Lena Point Fence: 141191 - Opening new event 503, alarm start]
12/08/23 11:11:13.720010 zmc_m3[16880].WAR-zm_monitor.cpp/2090 [Lena Point Fence: 141191 - event 503, has exceeded desired section length. 1702066273 - 1702056858 = 9415 >= 600]
12/08/23 11:11:13.720318 zmc_m3[17617].INF-zm_videostore.cpp/532 [some options not used, turn on debugging for a list.]
12/08/23 11:11:13.721364 zmc_m3[17619].INF-zm_videostore.cpp/532 [some options not used, turn on debugging for a list.]
12/08/23 11:11:16.601504 zmc_m3[16835].INF-zm_monitor.cpp/1680 [Lena Point Fence: 141300 - Capturing at 15.00 fps, capturing bandwidth 213704bytes/sec Analysing at 0.00 fps]
12/08/23 11:11:23.267855 zmc_m3[16835].INF-zm_monitor.cpp/1680 [Lena Point Fence: 141400 - Capturing at 15.00 fps, capturing bandwidth 97145bytes/sec Analysing at 0.00 fps]
12/08/23 11:11:26.119592 zmc_m3[16880].INF-zm_monitor.cpp/2016 [Lena Point Fence: 141377 - Gone into alert state]
12/08/23 11:11:26.119631 zmc_m3[16880].INF-zm_monitor.cpp/2024 [Lena Point Fence: 141378 - Left alarm state (504) - 186(186) images]
12/08/23 11:11:26.119639 zmc_m3[16880].INF-zm_monitor.cpp/2029 [Lena Point Fence: 141378 - Closing event 504, alarm end]
- Screenshot 2023-12-08 at 12.30.20 PM.png (538.5 KiB) Viewed 6914 times
I think I figured it out, I had to make sure my Maximum Image Buffer Size was set right, though I'm not sure why that would affect this.
