I edited the monitor and enabled ONVIF from a previously capturing monitor. Here is the log after that, sanitized for IP address:
02/22/24 18:32:34.486053 zmc_m6[545548].DB1-zm_db.cpp/205 [Success running sql query INSERT INTO Monitor_Status (MonitorId,Status) VALUES (6, 'NotRunning') ON DUPLICATE KEY UPDATE Status='NotRunning', thread_id: 177620]
02/22/24 18:32:34.486066 zmc_m6[545548].DB1-zm_monitor.cpp/3402 [Stopping packetqueue]
02/22/24 18:32:34.486069 zmc_m6[545548].DB1-zm_monitor.cpp/3408 [Decoder stopping]
02/22/24 18:32:34.486072 zmc_m6[545548].DB1-zm_monitor.cpp/3410 [Decoder stopped]
02/22/24 18:32:34.486074 zmc_m6[545548].DB1-zm_monitor.cpp/3415 [Analysis stopped]
02/22/24 18:32:34.486112 zmc_m6[545548].DB1-zmc.cpp/388 [Cleared monitors]
02/22/24 18:32:34.486130 zmc_m6[545548].DB1-zmc.cpp/392 [terminating]
02/22/24 18:32:34.492890 zmc_m6[545548].DB1-zm_db.cpp/109 [Closing database. Connection id was 177620]
02/22/24 18:32:35.849923 zmc_m6[1102224].DB1-zm_logger.cpp/225 [LogOpts: level=DB3 effective=DB3, screen=OFF, database=INF, logfile=DB9->/var/log/zoneminder/zmc_m6.log, syslog=WAR]
02/22/24 18:32:35.849988 zmc_m6[1102224].DB1-zm_utils.cpp/228 [Detected a x86\x86-64 processor with AVX2]
02/22/24 18:32:35.850507 zmc_m6[1102224].DB2-zm_storage.cpp/61 [Loading Storage for 2 using SELECT `Id`, `Name`, `Path`, `Type`, `Scheme` FROM `Storage` WHERE `Id`=2]
02/22/24 18:32:35.850576 zmc_m6[1102224].DB1-zm_storage.cpp/79 [Loaded Storage area 2 'NewStorage']
02/22/24 18:32:35.850579 zmc_m6[1102224].DB1-zm_monitor.cpp/400 [Have camera type Ffmpeg]
02/22/24 18:32:35.850584 zmc_m6[1102224].DB3-zm_monitor.cpp/492 [Decoding: 5 savejpegs 0 videowriter 2]
02/22/24 18:32:35.850589 zmc_m6[1102224].DB1-zm_packetqueue.cpp/739 [Setting pre_event_video_packet_count to 5]
02/22/24 18:32:35.850592 zmc_m6[1102224].DB1-zm_packetqueue.cpp/733 [Setting max_video_packet_count to 0]
02/22/24 18:32:35.850605 zmc_m6[1102224].DB2-zm_camera.cpp/69 [New camera id: 6 width: 3840 line size: 15360 height: 2160 colours: 4 subpixelorder: 8 capture: 1, size: 33177600]
02/22/24 18:32:35.850616 zmc_m6[1102224].INF-zm_ffmpeg.cpp/83 [Enabling ffmpeg logs, as LOG_DEBUG+LOG_FFMPEG are enabled in options]
02/22/24 18:32:35.850667 zmc_m6[1102224].DB2-zmc.cpp/218 [1 monitors loaded]
02/22/24 18:32:35.850670 zmc_m6[1102224].INF-zmc.cpp/221 [Starting Capture version 1.37.51]
02/22/24 18:32:35.850682 zmc_m6[1102224].DB3-zm_monitor.cpp/2468 [Reloading zones for monitor CAM6 have 0]
02/22/24 18:32:35.851172 zmc_m6[1102228].DB1-zm_db.cpp/205 [Success running sql query INSERT INTO `Logs` ( `TimeKey`, `Component`, `ServerId`, `Pid`, `Level`, `Code`, `Message`, `File`, `Line` ) VALUES ( 1708651955.850616, 'zmc_m6', 0, 1102224, 0, 'INF', 'Enabling ffmpeg logs, as LOG_DEBUG+LOG_FFMPEG are enabled in options', 'zm_ffmpeg.cpp', 83 ), thread_id: 194091]
02/22/24 18:32:35.851578 zmc_m6[1102228].DB1-zm_db.cpp/205 [Success running sql query INSERT INTO `Logs` ( `TimeKey`, `Component`, `ServerId`, `Pid`, `Level`, `Code`, `Message`, `File`, `Line` ) VALUES ( 1708651955.850670, 'zmc_m6', 0, 1102224, 0, 'INF', 'Starting Capture version 1.37.51', 'zmc.cpp', 221 ), thread_id: 194091]
02/22/24 18:32:35.851746 zmc_m6[1102224].DB1-zm_zone.cpp/842 [Got 1 zones for monitor CAM6]
02/22/24 18:32:35.851751 zmc_m6[1102224].DB3-zm_zone.cpp/770 [Got coordinate 0,0 from polygon string]
02/22/24 18:32:35.851754 zmc_m6[1102224].DB3-zm_zone.cpp/770 [Got coordinate 2365,0 from polygon string]
02/22/24 18:32:35.851756 zmc_m6[1102224].DB3-zm_zone.cpp/770 [Got coordinate 2367,207 from polygon string]
02/22/24 18:32:35.851765 zmc_m6[1102224].DB3-zm_zone.cpp/770 [Got coordinate 3824,203 from polygon string]
02/22/24 18:32:35.851767 zmc_m6[1102224].DB3-zm_zone.cpp/770 [Got coordinate 3839,2159 from polygon string]
02/22/24 18:32:35.851770 zmc_m6[1102224].DB3-zm_zone.cpp/770 [Got coordinate 0,2159 from polygon string]
02/22/24 18:32:35.851772 zmc_m6[1102224].DB3-zm_zone.cpp/782 [Successfully parsed polygon string 0,2159]
02/22/24 18:32:35.901221 zmc_m6[1102224].DB1-zm_monitor.cpp/2470 [Reloading zones for monitor CAM6 have 1]
02/22/24 18:32:35.901236 zmc_m6[1102224].DB1-zm_monitor.cpp/864 [SharedData=856 TriggerData=560 zone_count 1 * sizeof int 4 VideoStoreData=4128 timestamps=48 images=3x33177600 = 99532800 analysis images=3x33177600 = 99532800 image_format = 3x4 = 12 total=199071272]
02/22/24 18:32:35.901324 zmc_m6[1102224].DB3-zm_monitor.cpp/897 [Success opening mmap file at (/dev/shm/zm.mmap.6)]
02/22/24 18:32:35.901336 zmc_m6[1102224].DB3-zm_monitor.cpp/930 [MMap file size is 0]
02/22/24 18:32:35.901344 zmc_m6[1102224].DB1-zm_monitor.cpp/935 [Unable to map file /dev/shm/zm.mmap.6 (199071272 bytes) to locked memory, trying unlocked]
02/22/24 18:32:35.901356 zmc_m6[1102224].DB1-zm_monitor.cpp/938 [Mapped file /dev/shm/zm.mmap.6 (199071272 bytes) to unlocked memory]
02/22/24 18:32:35.901370 zmc_m6[1102224].DB3-zm_monitor.cpp/973 [Aligning shared memory images to the next 64 byte boundary 0x7f83982275dc to 0x7f8398227600 moved 36 bytes]
02/22/24 18:32:36.055333 zmc_m6[1102224].DB1-zm_monitor.cpp/2476 [Reloading linked monitors for monitor CAM6, '']
02/22/24 18:32:36.055370 zmc_m6[1102224].DB1-zm_monitor.cpp/1059 [Starting ONVIF]
02/22/24 18:32:36.056347 zmc_m6[1102224].DB1-zm_monitor.cpp/1087 [ONVIF Endpoint:
http://X.X.X.X.56/onvif/event_service/Events]
02/22/24 18:32:36.861382 zmc_m6[1102224].DB1-zm_monitor.cpp/1103 [ONVIF :soap_wsa_request OK ]
02/22/24 18:32:56.206187 zmc_m6[1102224].DB1-zm_monitor.cpp/1110 [Good Initial ONVIF Pull0 (null), (null)]
02/22/24 18:32:56.206261 zmc_m6[1102224].DB1-zm_monitor.cpp/1123 [ONVIF :soap_wsa_request OK]
02/22/24 18:32:56.212018 zmc_m6[1102224].DB1-zm_monitor.cpp/1132 [Good Initial ONVIF Renew 0 (null), (null)]
02/22/24 18:32:56.212035 zmc_m6[1102224].DB3-zm_monitor.cpp/1179 [Success connecting]
02/22/24 18:32:56.212964 zmc_m6[1102224].DB1-zm_db.cpp/205 [Success running sql query INSERT INTO Monitor_Status (MonitorId,Status,CaptureFPS,AnalysisFPS,CaptureBandwidth) VALUES (6, 'Running',0,0,0) ON DUPLICATE KEY UPDATE Status='Running',CaptureFPS=0,AnalysisFPS=0,CaptureBandwidth=0, thread_id: 194091]
02/22/24 18:32:56.212986 zmc_m6[1102224].DB1-zm_ffmpeg_camera.cpp/177 [Priming capture from rtsp://X.X.X.X.56/stream0]
02/22/24 18:32:56.213017 zmc_m6[1102224].DB1-zm_ffmpeg_camera.cpp/344 [Calling avformat_open_input for rtsp://X.X.X.X.56/stream0]
02/22/24 18:32:56.213068 zmc_m6[1102224].DB1-zm_ffmpeg_camera.cpp/354 [Rebuilt URI with encoded parameters: 'rtsp://admin:LetsSee117@X.X.X.X.56/stream0']
02/22/24 18:32:56.213219 zmc_m6[1102224].DB3-zm_ffmpeg.cpp/68 [No default whitelist set]
02/22/24 18:32:56.213250 zmc_m6[1102224].DB3-zm_ffmpeg.cpp/68 [Original list of addresses:]
02/22/24 18:32:56.213259 zmc_m6[1102224].DB3-zm_ffmpeg.cpp/68 [Address X.X.X.X.56 port 554]
02/22/24 18:32:56.213266 zmc_m6[1102224].DB3-zm_ffmpeg.cpp/68 [Interleaved list of addresses:]
02/22/24 18:32:56.213273 zmc_m6[1102224].DB3-zm_ffmpeg.cpp/68 [Address X.X.X.X.56 port 554]
02/22/24 18:32:56.213281 zmc_m6[1102224].DB2-zm_ffmpeg.cpp/68 [Starting connection attempt to X.X.X.X.56 port 554]
02/22/24 18:32:56.213388 zmc_m6[1102224].DB1-zm_ffmpeg_camera.cpp/627 [Received terminate in cb]
02/22/24 18:32:56.213422 zmc_m6[1102224].ERR-zm_ffmpeg_camera.cpp/359 [Unable to open input rtsp://X.X.X.X.56/stream0 due to: Immediate exit requested]
02/22/24 18:32:56.214007 zmc_m6[1102228].DB1-zm_db.cpp/205 [Success running sql query INSERT INTO `Logs` ( `TimeKey`, `Component`, `ServerId`, `Pid`, `Level`, `Code`, `Message`, `File`, `Line` ) VALUES ( 1708651976.213422, 'zmc_m6', 0, 1102224, -2, 'ERR', 'Unable to open input rtsp://X.X.X.X.56/stream0 due to: Immediate exit requested', 'zm_ffmpeg_camera.cpp', 359 ), thread_id: 194091]
02/22/24 18:32:56.214562 zmc_m6[1102224].DB1-zm_db.cpp/205 [Success running sql query INSERT INTO Monitor_Status (MonitorId,Status) VALUES (6, 'NotRunning') ON DUPLICATE KEY UPDATE Status='NotRunning', thread_id: 194091]
02/22/24 18:32:56.214582 zmc_m6[1102224].DB1-zmc.cpp/388 [Cleared monitors]
02/22/24 18:32:56.214607 zmc_m6[1102224].DB1-zmc.cpp/392 [terminating]
02/22/24 18:32:56.214615 zmc_m6[1102224].DB1-zm_db.cpp/109 [Closing database. Connection id was 194091]
02/22/24 18:33:01.374132 zmc_m6[1102296].DB1-zm_logger.cpp/225 [LogOpts: level=DB3 effective=DB3, screen=OFF, database=INF, logfile=DB9->/var/log/zoneminder/zmc_m6.log, syslog=WAR]
02/22/24 18:33:01.374176 zmc_m6[1102296].DB1-zm_utils.cpp/228 [Detected a x86\x86-64 processor with AVX2]
02/22/24 18:33:01.374618 zmc_m6[1102296].DB2-zm_storage.cpp/61 [Loading Storage for 2 using SELECT `Id`, `Name`, `Path`, `Type`, `Scheme` FROM `Storage` WHERE `Id`=2]
02/22/24 18:33:01.374673 zmc_m6[1102296].DB1-zm_storage.cpp/79 [Loaded Storage area 2 'NewStorage']
02/22/24 18:33:01.374677 zmc_m6[1102296].DB1-zm_monitor.cpp/400 [Have camera type Ffmpeg]
02/22/24 18:33:01.374682 zmc_m6[1102296].DB3-zm_monitor.cpp/492 [Decoding: 5 savejpegs 0 videowriter 2]
02/22/24 18:33:01.374697 zmc_m6[1102296].DB1-zm_packetqueue.cpp/739 [Setting pre_event_video_packet_count to 5]
02/22/24 18:33:01.374699 zmc_m6[1102296].DB1-zm_packetqueue.cpp/733 [Setting max_video_packet_count to 0]
02/22/24 18:33:01.374707 zmc_m6[1102296].DB2-zm_camera.cpp/69 [New camera id: 6 width: 3840 line size: 15360 height: 2160 colours: 4 subpixelorder: 8 capture: 1, size: 33177600]
02/22/24 18:33:01.374718 zmc_m6[1102296].INF-zm_ffmpeg.cpp/83 [Enabling ffmpeg logs, as LOG_DEBUG+LOG_FFMPEG are enabled in options]
02/22/24 18:33:01.374746 zmc_m6[1102296].DB2-zmc.cpp/218 [1 monitors loaded]
02/22/24 18:33:01.374748 zmc_m6[1102296].INF-zmc.cpp/221 [Starting Capture version 1.37.51]
02/22/24 18:33:01.374823 zmc_m6[1102296].DB3-zm_monitor.cpp/2468 [Reloading zones for monitor CAM6 have 0]
02/22/24 18:33:01.375584 zmc_m6[1102297].DB1-zm_db.cpp/205 [Success running sql query INSERT INTO `Logs` ( `TimeKey`, `Component`, `ServerId`, `Pid`, `Level`, `Code`, `Message`, `File`, `Line` ) VALUES ( 1708651981.374718, 'zmc_m6', 0, 1102296, 0, 'INF', 'Enabling ffmpeg logs, as LOG_DEBUG+LOG_FFMPEG are enabled in options', 'zm_ffmpeg.cpp', 83 ), thread_id: 194107]
02/22/24 18:33:01.376073 zmc_m6[1102297].DB1-zm_db.cpp/205 [Success running sql query INSERT INTO `Logs` ( `TimeKey`, `Component`, `ServerId`, `Pid`, `Level`, `Code`, `Message`, `File`, `Line` ) VALUES ( 1708651981.374748, 'zmc_m6', 0, 1102296, 0, 'INF', 'Starting Capture version 1.37.51', 'zmc.cpp', 221 ), thread_id: 194107]
02/22/24 18:33:01.376212 zmc_m6[1102296].DB1-zm_zone.cpp/842 [Got 1 zones for monitor CAM6]
02/22/24 18:33:01.376218 zmc_m6[1102296].DB3-zm_zone.cpp/770 [Got coordinate 0,0 from polygon string]
02/22/24 18:33:01.376220 zmc_m6[1102296].DB3-zm_zone.cpp/770 [Got coordinate 2365,0 from polygon string]
02/22/24 18:33:01.376223 zmc_m6[1102296].DB3-zm_zone.cpp/770 [Got coordinate 2367,207 from polygon string]
02/22/24 18:33:01.376225 zmc_m6[1102296].DB3-zm_zone.cpp/770 [Got coordinate 3824,203 from polygon string]
02/22/24 18:33:01.376227 zmc_m6[1102296].DB3-zm_zone.cpp/770 [Got coordinate 3839,2159 from polygon string]
02/22/24 18:33:01.376230 zmc_m6[1102296].DB3-zm_zone.cpp/770 [Got coordinate 0,2159 from polygon string]
02/22/24 18:33:01.376232 zmc_m6[1102296].DB3-zm_zone.cpp/782 [Successfully parsed polygon string 0,2159]
02/22/24 18:33:01.429653 zmc_m6[1102296].DB1-zm_monitor.cpp/2470 [Reloading zones for monitor CAM6 have 1]
02/22/24 18:33:01.429679 zmc_m6[1102296].DB1-zm_monitor.cpp/864 [SharedData=856 TriggerData=560 zone_count 1 * sizeof int 4 VideoStoreData=4128 timestamps=48 images=3x33177600 = 99532800 analysis images=3x33177600 = 99532800 image_format = 3x4 = 12 total=199071272]
02/22/24 18:33:01.429721 zmc_m6[1102296].DB3-zm_monitor.cpp/897 [Success opening mmap file at (/dev/shm/zm.mmap.6)]
02/22/24 18:33:01.429729 zmc_m6[1102296].DB3-zm_monitor.cpp/930 [MMap file size is 199071272]
02/22/24 18:33:01.429742 zmc_m6[1102296].DB1-zm_monitor.cpp/935 [Unable to map file /dev/shm/zm.mmap.6 (199071272 bytes) to locked memory, trying unlocked]
02/22/24 18:33:01.429766 zmc_m6[1102296].DB1-zm_monitor.cpp/938 [Mapped file /dev/shm/zm.mmap.6 (199071272 bytes) to unlocked memory]
02/22/24 18:33:01.429771 zmc_m6[1102296].DB3-zm_monitor.cpp/973 [Aligning shared memory images to the next 64 byte boundary 0x7f73c02275dc to 0x7f73c0227600 moved 36 bytes]
02/22/24 18:33:01.516186 zmc_m6[1102296].DB1-zm_monitor.cpp/2476 [Reloading linked monitors for monitor CAM6, '']
02/22/24 18:33:01.516218 zmc_m6[1102296].DB1-zm_monitor.cpp/1059 [Starting ONVIF]
02/22/24 18:33:01.517623 zmc_m6[1102296].DB1-zm_monitor.cpp/1087 [ONVIF Endpoint:
02/22/24 18:33:01.570320 zmc_m6[1102296].DB1-zm_monitor.cpp/1103 [ONVIF :soap_wsa_request OK ]
Regards,
Mark
