I have two different computers with zoneminder,
One with the apt repository of iconnor-ubuntu-zoneminder-1_36-focal.list upgrades to 1.36.33 as expected. {focal is Ubuntu 20.04}
The other with the apt repository of iconnor-ubuntu-zoneminder-1_36-jammy.list upgrades to 1.36.12. Is that intentional? {jammy is Ubuntu 22.04}
I was looking for differences between the two since on the computer on Ubuntu jammy, zoneminder is not working. and previously it was working before upgrading to jammy.
Upgrade oddity 1.36.x
Re: Upgrade oddity 1.36.x
They should be on the same version -.33
Something's not right on your jammy updater.
use apt-cache madison zoneminder to see what is available.
Re: Upgrade jammy 1.36.33
I have the same issue with Ubuntu 22.04.3, it doesn't let me upgrade to zoneminder 1.36.33 from 1.36.12.
Running "apt-cache madison zoneminder" gives me:
zoneminder | 1.36.33-jammy1 | https://ppa.launchpadcontent.net/iconno ... .36/ubuntu jammy/main amd64 Packages
zoneminder | 1.36.12+dfsg1-1ubuntu0.1~esm1 | https://esm.ubuntu.com/apps/ubuntu jammy-apps-security/main amd64 Packages
zoneminder | 1.36.12+dfsg1-1 | http://gb.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
It could be because of the subscription I have to Ubuntu Pro, but I have commented the appropriate lines and still can't upgrade. Running "apt-get update" doesn't do anything, but "apt-get upgrade zoneminder" returns:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
zoneminder : Depends: libdatetime-perl but it is not installable
Depends: libfile-slurp-perl but it is not installable
Depends: php-intl but it is not installable
Depends: libvncclient1 but it is not installable or
libvncclient0 but it is not installable
Recommends: zoneminder-doc (>= 1.36.33-jammy1) but 1.36.12+dfsg1-1ubuntu0.1~esm1 is to be installed
E: Broken packages
E: Broken packages
Did you try to fix the broken packages?
There is something seriously wrong with your system. Those not installable dependencies are definitely generally available and have been for years.
You must be missing some normally available repo in sources.list.
@dougmccrary - I have tried to fix them, but no joy.
@iconnor - I'll try Debian, not very happy with Ubuntu anyway. Below is my repos in sources.list
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://gb.archive.ubuntu.com/ubuntu jammy main restricted
# deb-src http://gb.archive.ubuntu.com/ubuntu jammy main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://gb.archive.ubuntu.com/ubuntu jammy-updates main restricted
# deb-src http://gb.archive.ubuntu.com/ubuntu jammy-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://gb.archive.ubuntu.com/ubuntu jammy universe
# deb-src http://gb.archive.ubuntu.com/ubuntu jammy universe
deb http://gb.archive.ubuntu.com/ubuntu jammy-updates universe
# deb-src http://gb.archive.ubuntu.com/ubuntu jammy-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://gb.archive.ubuntu.com/ubuntu jammy multiverse
# deb-src http://gb.archive.ubuntu.com/ubuntu jammy multiverse
deb http://gb.archive.ubuntu.com/ubuntu jammy-updates multiverse
# deb-src http://gb.archive.ubuntu.com/ubuntu jammy-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://gb.archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
# deb-src http://gb.archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu/ jammy-security main restricted
# deb-src http://security.ubuntu.com/ubuntu/ jammy-security main restricted
deb http://security.ubuntu.com/ubuntu/ jammy-security universe
# deb-src http://security.ubuntu.com/ubuntu/ jammy-security universe
deb http://security.ubuntu.com/ubuntu/ jammy-security multiverse
# deb-src http://security.ubuntu.com/ubuntu/ jammy-security multiverse
## distribution.
## security team.
If you're gonna reinstall, you may as well go with ubuntu. It works fine, even with ubuntu pro.
Except for LAMP, there are good instructions in the wiki that work for 18.04 and up, in my experience.
This was a VM fresh install and it didn't work. Maybe I missed something, but still it shouldn't be unfixable or un-upgradable.
Well something's not right. It works on metal.
