Page 1 of 1
Three Dots on Android Devices
Posted: Mon Jan 15, 2024 3:49 pm
by ireduts
Hello everyone,
i have installed zmninja on several cell phones. On Android devices (Android 12 / 13) i now have the problem that no videos are displayed. Only three green dots appear where the video should be. A broken image icon is displayed in the live views. Funnily enough, it works on my iPhone. I transferred the settings from the iPhone to the Android devices without success. I checked whether the API works. That's what it does, otherwise it wouldn't work on the iPhone.
Here are the version details:
ZM - v.1.36.33
zmNinja IOS - 1.6.009
zmNinja Android - 1.7.002
ZM is a great piece of software. It would be a shame if I couldn't solve this problem.Thanks in advance.
Re: Three Dots on Android Devices
Posted: Mon Jan 15, 2024 10:30 pm
by iconnor
android will no longer load images that aren't https. So setup SSL.
Posted: Tue Oct 08, 2024 8:38 pm
by 2ndAmendment
I just installed zmninja on a Samsung Note 10+. I am running ZM 1.36.34 on Apache using HTTPS. Camera resolution is 2688*1520 4MP.
I get the three dots for the montage view and the monitor -> View live.
All the event videos play back just fine in zmninja.
I also can open ZM on Firefox for mobile and all videos including montage and monitor play just fine.
I have read the docs and confirmed the API is working.
So what is different about video playback between event videos and live videos? Is there a configuration item(s) that need to be set in ZM or zmninja?
Posted: Tue Dec 03, 2024 3:06 am
by secfalcon
Know this is old, but in case it helps anyone...
I had the same issue after upgrading to the new zmNinja Android app. I use https remotely and http within my local network. Live streaming was working fine internally (http), but not externally (https).
My issue was the URLs configured when setting up zmNinja - specifically the path to cgi-bin.
ZM portal url
https://<myserver>/zm
path to cgi-bin
https://<myserver>/zm/cgi-bin <--- autoconfigured by the wizard and did NOT work
https://<myserver>/cgi-bin <--- my update to remove "/zm" path only for the cgi-bin resolves the issue
