Can not add or edit cameras unless logged in.
Burtski
Post by Burtski »
1.37.50 - Ubuntu 20.04.6
I can not add or edit cameras if I am not logged in.
So with OPT_USE_AUTH unchecked I can not log in, therefore can not make edits.
Works fine if I enable OPT_USE_AUTH, but then I have to login.
Very minor. Just pointing it out.
Re: Can not add or edit cameras unless logged in.
Or, you could just turn it off completely.
Are you sure about the ZM version? Because I fixed that problem on Jan 14th which would have been 1.37.49
Don't know for sure about earlier versions of 1.37.50, but the one built today works as I'd expect.
Burtski
Post by Burtski »
Sorry, My bad.
Works as expected on 1.37.50.
I originally set things up on 1.37.48
