http://server/zm/api/monitors.json on the machine with zoneminder seems ok.
When I look at this same address on my tablet logined to zoneminder first.
It is just a bunch of strings of txt, not in the table format like my attached photo.
I think I have an issue with my API, not sure where to look
- Screenshot from 2024-01-22 17-52-03.png (30.83 KiB) Viewed 4293 times
Re: I think I have an issue with my API, not sure where to look
That surprises me. Mine looks like your posted example.the machine with zoneminder seems ok.
I agree, that's was on the machine running zoneminder.
My phone/tablet trying to run ZmNinja
- Screenshot_20240122_184709_Chrome.jpg (132.58 KiB) Viewed 4281 times
Just a guess, but maybe https:// ?
I can access zoneminder HTTP but not HTTPS
Yeah...ISTR something about android needing https in later versions.
Don't mean to send you down a rathole, but I suspect that's at the bottom of this.
I don't use ninja at present so that's all I got. Sorry, and good luck.
(a better screenshot of the error on phone might be helpful)
I reinstalled the older zmNinjaPro which prompts for http or https and I choose http and basically it works.
So maybe there is something with https...
http vs https shouldn't be an issue here. It only seems to affect image loading.
The response is pretty clear, Not Authenticated. The question is, why?
Not sure what I did...
I am now HTTPS with SSL and everything seems to be working
