Support for 8k or more cameras in "Viewing" & "Montage"
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
IgorA100
Post by IgorA100 »
When using a camera with stream:
resolution - 3840x2160 px
frame rate - 15 fps
bite rat - 16384 kbps
and settings in ZM
Capture Resolution (pixels) - 1280x720 720p
Memory consumption during live viewing is more than 15GB!!! It's not really a lot.
As an option, in the “Viewing” section, add the ability to select a second stream and resolution for displaying it.
ADD:
Also, I think it would be optimal for Janus to also specify the thread, and not use only the first one. This will save traffic.
IgorA100
Re: Support for 8k or more cameras in "Viewing" & "Montage"
Post by IgorA100 »
I think that the situation will improve noticeably if it is possible to use not only the first, but also the second or third stream for live viewing & Montage !
