zmNinja mobile app port issue
zmcab
Post by zmcab »
Because I have more than one Apache server at home; the one with zoneminder uses Port 81 instead of 80. Works fine to access zm via http on a brower by specifiying the port (:81)
However with the zmNinja app; specifying the port doesn't work. If I look at the log file I can see that the port specified in API calls is 80 or not specified which will default to 80.
Is this a bug/feature not supported or am I specifying the wrong way i.e. <serverip:81/zm/index.php>
Re: zmNinja mobile app port issue
Probably a bug. Will take a look. Make sure you are on the latest 1.7.006
zmcab
Post by zmcab »
Yes, v1.7.006
thx
