The communication channel consists of a managed switch to which the server and the cameras themselves are connected within 10 meters.
SNMP analysis of the communication channel does not find any problems in the communication channel, there is no packet loss.
I tried both TCP and UDP, there is no difference. I tried fiddling with the Janus settings, but it's no use
I don't know how to check the problem in Janus or in ZM
I'm sad.
I'm using Janus version: 1102 (1.1.2)
Maybe someone has dealt with this problem?
If it were possible to get rid of the constant mute/unmute it would be very cool!
