Export ZM configuration without copying the entire database.
User6677
Post by User6677 »
I'm running ZM 1.36 and sadly my DB got corrupted and the backup overwritten with corrupted data before I noticed.
I repaired the DB as much as possible (by using sql recovery mode, then creating a new ZM DB and importing recovered data). But certain features are not working right.
So I need to start from scratch, but I'd like to copy my monitor config (especially motion detection areas) which I've been tweaking and improving for a long time.
Which DB tables contain:
- motion detection areas
- monitor config?
And will I have to fix any data manually afterwards? Does anyone here know?
Re: Export ZM configuration without copying the entire database.
- monitor config?
-Zones
-Monitors
You might want to look at https://wiki.zoneminder.com/MySQL
User6677
Post by User6677 »
dougmccrary wrote: Sat Mar 02, 2024 8:32 am
- monitor config?
-Zones
-Monitors
Thank you :-)
