Correct browser settings??
TommyGun
Post by TommyGun »
Does anyone know how to set up correct settings in browser, for examle in mozilla or IE? The problem is that when i check "stream" - there is no video in window. Sometimes i got it, sometimes no. When i check "Stills" - i got pictures. Always.
Something about cache settings or..?
Thank You
gneuf
Post by gneuf »
I just hit refresh once or twice, and volia! The stream video come back.
Make sure your using cambozola streaming option - it makes all the difference in having ZoneMinder work with a variey of Browsers...
And check that your browsers are all using the most recent Java plugin on the client platform...In Windoze look in the Control Panel for the Java Plugin.
sema
Post by sema »
gneuf wrote:I just hit refresh once or twice, and volia! The stream video come back.
it no rule...
i have this problem to
at version 0.9.12 all work good
at newest versions - stream stopped after 5-20 seconds in Netscape 4.5-6.2 and Mozilla 1.6 (preferenses in that brousers same as for ZM 0.9.12)
zoneminder
Site Admin
Post by zoneminder »
Trying experimenting with using nph-zms instead of plain zms and seeing if that makes any difference.
Phil,
