There is one frame for the length of the event plus post event buffer time.
They appear to be recording for the correct amount of time but there is just one still frame.
The log file is full of:
3/2/24, 5:02:51 PM CST zmc_m18 267924 ERR Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(clone+0x43) [0x7f997d85d353] zm_signal.cpp 107
3/2/24, 5:02:51 PM CST zmc_m18 267924 ERR Backtrace 5: /lib/x86_64-linux-gnu/libpthread.so.0(+0x8609) [0x7f997e4af609] zm_signal.cpp 107
3/2/24, 5:02:51 PM CST zmc_m18 267924 ERR Backtrace 4: /lib/x86_64-linux-gnu/libstdc++.so.6(+0xd6df4) [0x7f997db72df4] zm_signal.cpp 107
3/2/24, 5:02:51 PM CST zmc_m18 267924 ERR Backtrace 3: /usr/bin/zmc(+0x1cb751) [0x55c015f6f751] zm_signal.cpp 107
3/2/24, 5:02:51 PM CST zmc_m18 267924 ERR Backtrace 2: /usr/bin/zmc(+0x83f54) [0x55c015e27f54] zm_signal.cpp 107
3/2/24, 5:02:51 PM CST zmc_m18 267924 ERR Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x14420) [0x7f997e4bb420] zm_signal.cpp 107
3/2/24, 5:02:51 PM CST zmc_m18 267924 ERR Backtrace 0: /usr/bin/zmc(+0xffd69) [0x55c015ea3d69] zm_signal.cpp 107
3/2/24, 5:02:51 PM CST zmc_m18 267924 ERR Signal address is 0xc4, from 0x55c015e27f54 zm_signal.cpp 82
3/2/24, 5:02:51 PM CST zmc_m18 267924 ERR Got signal 11 (Segmentation fault), crashing zm_signal.cpp 50
Both high resolution monitors that are triggered from low res monitors are doing this.
Also just noticed these warnings:
3/2/24, 5:22:59 PM CST zmc_m19 268785 WAR You have set the max video packets in the queue to 121. The queue is full. Either Analysis is not keeping up or your camera's keyframe interval 14 is larger than this setting. zm_packetqueue.cpp 155
3/2/24, 5:22:56 PM CST zmc_m18 268781 WAR You have set the max video packets in the queue to 121. The queue is full. Either Analysis is not keeping up or your camera's keyframe interval 19 is larger than this setting. zm_packetqueue.cpp 155
3/2/24, 5:22:47 PM CST zmdc 173457 WAR 'zmc -m 19' has not stopped at 24/03/02 17:22:47 after 30 seconds. Sending KILL to pid 268203 zmdc.pl -
3/2/24, 5:22:47 PM CST zmdc 173457 WAR 'zmc -m 18' has not stopped at 24/03/02 17:22:47 after 30 seconds. Sending KILL to pid 268199 zmdc.pl -
