[Fixed]Vertical scroll bar probleme
phil56
Post by phil56 »
I've just installed the latest version 1.37.55 and I'm having a problem with the vertical scrollbars. They're no longer displayed in the settings page, for example, or in the events list. Same thing on Chrome (Brave) and Edge.
Thanks in advance
Phil
Re: Vertical scroll bar probleme
Fixed, new packages building
phil56
Post by phil56 »
Thanks for the quick reply,
I've just updated.
Now, in the settings page it's fine, but not in the events list.
Thanks in advance
Phil
IgorA100
Post by IgorA100 »
phil56 wrote: Tue Mar 12, 2024 4:59 pm Now, in the settings page it's fine, but not in the events list.
Do you have screenshots? I can't understand the essence of the problem.
Have you cleared your browser cache?
IgorA100
Post by IgorA100 »
The problem will be fixed soon.
phil56
Post by phil56 »
Hi
the last version (1.37.55~20240313.143) seems to correct the problem.
thank you very much for your responsiveness
Phil
