DiskSpace: Event does not exist
GadgetChris
Post by GadgetChris »
My diskspace fulled up as the purge filters did not work properly, so I had to manually delete events to allow enough space for ZM to restart.
Now I'm getting constantly these warnings in the logs, and they don't seem to disappear. I first though it just would purge the indexes of all the deleted events, but I see the same event reported over again.
What is needed to clear the index?
zm-v1.36.33 in docker @ Ubuntu 22.04.4.LTS
Re: DiskSpace: Event does not exist
Those would eventually drop off, but you can expedite with
sudo zmaudit.pl
GadgetChris
    PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
2451688 root      20   0   47088  36480   2432 R  93.8   0.2 498:19.77 zmaudit.pl
2612198 911       20   0    7032   5760   1152 R  78.0   0.0   3:21.84 rm
2456700 911       20   0 2601296   2.0g  38528 S  72.1  13.1 341:37.29 zmc
1352027 911       20   0  621832 219352  11984 S   1.5   1.4 100:03.61 zmc
1351332 27        20   0 2676976 433744  10880 S   1.1   2.7 893:30.50 mysqld
zmaudit.pl has been running for the last 10 hours. I presume it will end on it's own when done, right?
Yep. It's slow. Lotsa look-ups.
