ONVIF problem (recording by detection is turned on very rarely)
IgorA100
Post by IgorA100 »
ZM = 1.37.55~20240315091333
The camera is Chinese, which very strangely generates ONVIF events.
The strange thing is that after publishing a discovery event, an event about the end of discovery is immediately published.
In this case, the event about the end of detection is published constantly with an interval of approximately 1 second! and so on ad infinitum. This is probably not the most correct camera algorithm.
Perhaps as a result of this, ZM records very rarely, i.e. For approximately 50 events, only one can be registered.
Permanent entries in the logs:
3/19/24, 5:02:20 PM GMT+3	zmc_m14		5771	INF	Triggered off ONVIF	zm_monitor.cpp	1901
3/19/24, 5:02:20 PM GMT+3	zmc_m14		5771	INF	Got Motion Alarm!	zm_monitor.cpp	1891
3/19/24, 5:02:20 PM GMT+3	zmc_m14		5617	INF	Clone of HeroSpeed_2Mp: 11600 - Capturing at 20.03 fps, capturing bandwidth 523298bytes/sec Analysing at 0.00 fps	zm_monitor.cpp	1831
3/19/24, 5:02:15 PM GMT+3	zmc_m14		5617	INF	Clone of HeroSpeed_2Mp: 11500 - Capturing at 20.00 fps, capturing bandwidth 539743bytes/sec Analysing at 0.00 fps	zm_monitor.cpp	1831
3/19/24, 5:02:10 PM GMT+3	zmc_m14		5771	INF	Triggered off ONVIF	zm_monitor.cpp	1901
3/19/24, 5:02:10 PM GMT+3	zmc_m14		5771	INF	Got Motion Alarm!	zm_monitor.cpp	1891
3/19/24, 5:02:10 PM GMT+3	zmc_m14		5617	INF	Clone of HeroSpeed_2Mp: 11400 - Capturing at 20.24 fps, capturing bandwidth 523407bytes/sec Analysing at 0.00 fps	zm_monitor.cpp	1831
3/19/24, 5:02:05 PM GMT+3	zmc_m14		5617	INF	Clone of HeroSpeed_2Mp: 11300 - Capturing at 19.76 fps, capturing bandwidth 519619bytes/sec Analysing at 0.00 fps	zm_monitor.cpp	1831
I am attaching the level 3 log (there was movement, but no recording occurred)
_debug.7z
(138.76 KiB) Downloaded 32 times
IgorA100
Re: ONVIF problem (recording by detection is turned on very rarely)
Post by IgorA100 »
The problem remains in the current version.
