[SOLVED]-Problems with new installation
asunturd
Post by asunturd »
I've been away from zm since 1.36.
I've made a fresh install on ubuntu 22.04 as per instructions from installation-video.
all seemed fine at first, I managed to add a monitor but didn't get any video output.
I used search feature and found my camera as a choice, added and when I didnt get it to work I just removed it again.
tried adding another monitor but gave up and deleted monitors.
today, a couple of days later I wanted to retry but I cannot add monitors anymore
logging refecenced to old monitors I had deleted, they weren't there in the console but logging still reported problems with stream(yes, these were wrong the time I tried)
So I logged into db directly and deleted the monitors form the table "Monitors"
I rebooted the ubuntu and tried again but no luck
When adding monitor nothing happens, no errors when pressing add button.
these are the errors before puring the table:
3/20/24, 9:57:02 PM GMT+1	zmc_m3	1531	ERR	Failed to prime capture of initial monitor	zmc.cpp	263
3/20/24, 9:57:02 PM GMT+1	zmc_m3	1531	ERR	Unable to open input rtsp://ip/videoMain due to: Connection refused	zm_ffmpeg_camera.cpp	367
there are some errors in the logs now:
3/20/24, 10:18:04 PM GMT+1	web_php	1830	ERR	Unknown tab general	/usr/share/zoneminder/www/skins/classic/views/monitor.php	1558
P.S. I also did upgrade to 1.37.56 today
the process completed without errors but no change in the behavior:
Setting up zoneminder (1.37.56~20240319145928-jammy) ...
detected systemd
Warning: The unit file, source configuration file or drop-ins of zoneminder.service changed on disk. Run 'systemctl daemon-reload' to reload units.
Detected db service is mysql.service
Checking for db
Db exists.
Updating permissions for user zmuser@localhost
Initiating database upgrade to version 1.37.56 from version 1.37.55
Upgrading database to version 1.37.56
Upgrading DB to 1.37.56 from 1.37.55
Database successfully upgraded to version 1.37.56.
Database upgrade to version 1.37.56 successful.
Freshening configuration in database
Migratings passwords, if any...
Loading config from DB 242 entries
Saving config to DB 242 entries
Done Updating
please advise
p.s:
I can also see that "console" button on gui is gone
and there are more errors in the logs and I dont have any monitors defined and "Monitors" table is empty
3/20/24, 9:51:48 PM GMT+1	zmc_m3	1531	ERR	Unable to open input rtsp://ip/videoMain due to: Connection refused	zm_ffmpeg_camera.cpp	367
3/20/24, 9:50:32 PM GMT+1	zmc_m3	1531	ERR	Failed to prime capture of initial monitor	zmc.cpp	263
3/20/24, 9:50:32 PM GMT+1	zmc_m3	1531	ERR	Unable to open input rtsp://ip/videoMain due to: Connection refused	zm_ffmpeg_camera.cpp	367
3/20/24, 9:49:17 PM GMT+1	zmc_m3	1531	ERR	Failed to prime capture of initial monitor	zmc.cpp	263
3/20/24, 9:49:17 PM GMT+1	zmc_m3	1531	ERR	Unable to open input rtsp://ip/videoMain due to: Connection refused	zm_ffmpeg_camera.cpp	367
3/20/24, 9:48:03 PM GMT+1	zmc_m3	1531	ERR	Failed to prime capture of initial monitor	zmc.cpp	263
3/20/24, 9:48:03 PM GMT+1	zmc_m3	1531	ERR	Unable to open input rtsp://ip/videoMain due to: Connection refused	zm_ffmpeg_camera.cpp	367
3/20/24, 9:47:03 PM GMT+1	web_php	2142	ERR	Unknown tab general	/usr/share/zoneminder/www/skins/classic/views/monitor.php	1558
3/20/24, 9:46:50 PM GMT+1	zmc_m3	1531	ERR	Failed to prime capture of initial monitor	zmc.cpp	263
3/20/24, 9:46:50 PM GMT+1	zmc_m3	1531	ERR	Unable to open input rtsp://ip/videoMain due to: Connection refused	zm_ffmpeg_camera.cpp	367
3/20/24, 9:45:38 PM GMT+1	zmc_m3	1531	ERR	Failed to prime capture of initial monitor	zmc.cpp	263
3/20/24, 9:45:38 PM GMT+1	zmc_m3	1531	ERR	Unable to open input rtsp://ip/videoMain due to: Connection refused	zm_ffmpeg_camera.cpp	367
3/20/24, 9:44:27 PM GMT+1	zmc_m3	1531	ERR	Failed to prime capture of initial monitor	zmc.cpp	263
3/20/24, 9:44:27 PM GMT+1	zmc_m3	1531	ERR	Unable to open input rtsp://ip/videoMain due to: Connection refused	zm_ffmpeg_camera.cpp	367
3/20/24, 9:43:17 PM GMT+1	zmc_m3	1531	ERR	Failed to prime capture of initial monitor	zmc.cpp	263
3/20/24, 9:43:17 PM GMT+1	zmc_m3	1531	ERR	Unable to open input rtsp://ip/videoMain due to: Connection refused	zm_ffmpeg_camera.cpp	367
3/20/24, 9:42:08 PM GMT+1	zmc_m3	1531	ERR	Failed to prime capture of initial monitor	zmc.cpp	263
3/20/24, 9:42:08 PM GMT+1	zmc_m3	1531	ERR	Unable to open input rtsp://ip/videoMain due to: Connection refused	zm_ffmpeg_camera.cpp	367
3/20/24, 9:42:05 PM GMT+1	web_php	945	ERR	Unknown tab general	/usr/share/zoneminder/www/skins/classic/views/monitor.php	1558
3/20/24, 9:41:00 PM GMT+1	zmc_m3	1531	ERR	Failed to prime capture of initial monitor	zmc.cpp	263
3/20/24, 9:41:00 PM GMT+1	zmc_m3	1531	ERR	Unable to open input rtsp://ip/videoMain due to: Connection refused	zm_ffmpeg_camera.cpp	367
3/20/24, 9:39:53 PM GMT+1	zmc_m3	1531	ERR	Failed to prime capture of initial monitor	zmc.cpp	263
3/20/24, 9:39:53 PM GMT+1	zmc_m3	1531	ERR	Unable to open input rtsp://ip/videoMain due to: Connection refused	zm_ffmpeg_camera.cpp	367
3/20/24, 9:39:36 PM GMT+1	web_php	945	ERR	Unknown tab general	/usr/share/zoneminder/www/skins/classic/views/monitor.php	1558
3/20/24, 9:38:47 PM GMT+1	zmc_m3	1531	ERR	Failed to prime capture of initial monitor	zmc.cpp	263
3/20/24, 9:38:47 PM GMT+1	zmc_m3	1531	ERR	Unable to open input rtsp://ip/videoMain due to: Connection refused	zm_ffmpeg_camera.cpp	367
3/20/24, 9:37:42 PM GMT+1	zmc_m3	1531	ERR	Failed to prime capture of initial monitor	zmc.cpp	263
3/20/24, 9:37:42 PM GMT+1	zmc_m3	1531	ERR	Unable to open input rtsp://ip/videoMain due to: Connection refused	zm_ffmpeg_camera.cpp	367
3/20/24, 9:36:38 PM GMT+1	zmc_m3	1531	ERR	Failed to prime capture of initial monitor	zmc.cpp	263
3/20/24, 9:36:38 PM GMT+1	zmc_m3	1531	ERR	Unable to open input rtsp://ip/videoMain due to: Connection refused	zm_ffmpeg_camera.cpp	367
Re: Problems with new installation
GUI problems sometimes result from old cookies. Try clearing them for zm.
Try your path in VLC. If it works there, it'll work in ZM, and VLC's faster than testing with ZM.
Not sure exactly what you did with the Monitors table, but try adding M3 again and then delete with GUI.
asunturd
Post by asunturd »
dougmccrary wrote: Thu Mar 21, 2024 12:53 am GUI problems sometimes result from old cookies. Try clearing them for zm.
Tried different browsers so that is not the issue
Yes, I have resolved the stream issues but cannot add monitors in GUI and as you can see logs referencing to a monitor which does not exist.
What I did to the table is just deleting the monitor manually from the table bacase of the same reason, the gui didn't show anything but logs were full of old references.
Can you get the console with [IP]/zm/index.php?view=console
? or did the button show up?
asunturd
Post by asunturd »
dougmccrary wrote: Thu Mar 21, 2024 10:40 am Can you get the console with [IP]/zm/index.php?view=console
Yes, it works either by your link or by directly accessing the ip/zm but the button is absent from the GUI, see the attachment
Screenshot 2024-03-21 202958.jpg (60.85 KiB) Viewed 1669 times
asunturd
Post by asunturd »
Just upgraded to 1.37.56~20240321124416-jammy
and all is back to normal :)
