Monitors 8mp, 5mp & 3mp
FPS 10-20
Up to 5 monitors there are no problems, everything is fine.
Then the problems begin:
- the image is displayed from only 5-7 monitors out of 12.
- the browser is terribly slow (any browsers, any computers running Windows)
- some requests are cancelled.
Bandwidth is set to LOW, channel 1 Gbit/s
In this case, the load on the server itself does not exceed 70%
Probably the problem is that AJAX requests do not have time to be processed?
I'm still at a loss on how to fix this.
Montage - problem when there are more than 5 monitors
- 300.png (176.21 KiB) Viewed 1460 times
Re: Montage - problem when there are more than 5 monitors
I tried setting WEB_L_REFRESH_STATUS=20, but the situation did not change globally
Is it really just me who has this problem?
This is a problem as old as time that has been dicussed here many times.
One way to work around it is to use multi-port.
https://medium.com/zmninja/multi-port-s ... 836a336c93
It really works!
Yes, I completely forgot about browser restrictions
It's easy to forget once it's set.
I keep the config saved in a couple places in case there's a crash.
