1.37.57~20240331.14-focal amd64 no console tab in navbar
MarsRover
Post by MarsRover »
no console tab in navbar after new install (or generally when no monitors defined)
/usr/share/zoneminder/www/skins/classic/includes/functions.php
line 654 - this check should be removed
 649 // Returns the html representing the Console menu item
 650 function getConsoleHTML() {
 651   global $user;
 652   $result = '';
 653
 654   if (count($user->viewableMonitorIds())) {
 655     $result .= '<li id="getConsoleHTML" class="nav-item"><a class="nav-link" href="?view=console">'.translate('Console').'</a></li>'.PHP_EOL;
 656   }
 657
 658   return $result;
 659 }
IgorA100
Re: 1.37.57~20240331.14-focal amd64 no console tab in navbar
Post by IgorA100 »
Are you sure your settings allow access to viewing monitors?
This part of the code checks the viewing resolution of the monitors.
We need to also check for existence of any monitors.
