Why is ZM "Stopped"?
borozenetsww
Post by borozenetsww »
Why status of ZM is "Stopped"?
Re: 1.37.57: Unable to connect IP camera as monitor
Don't know - why don't you start a new topic and give some details, like was it working?
rik
Post by rik »
@borozenetsww , if your question has to do with this particular thread:
i've found that ZM periodically quits, and needs a `sudo systemctl start zoneminder` to get it running again. Not sure why...
borozenetsww
Maybe need in first find reason of this condition? And then try to add a camera.
Re: Why is ZM "Stopped"?
Yes, find a reason.
Other than running out of memory I hardly ever see a stop. Even then it usually restarts itself.
(1.37 is sometimes broken, but even then it usually doesn't stop, just misbehaves or won't start to begin with.)
Is there something in the logs? If not do the restart and carry on.
Also, it's important to specify what build you're on - new ones come out sometimes two or three a day.
geraldbrandt
Post by geraldbrandt »
Mine stopped today with 1.37.58. I just upgraded from 1.37.55, which never stopped. I'll monitor and see if I can find a reason.
Gerald
There's a 1.37.59 now. I missed 1.37.58. I think.
geraldbrandt
.59 has been running fine for me.
