Page 1 of 1
Error in Montage Review
Posted: Sun Apr 21, 2024 9:20 pm
by flaviohenriquew
Hello!!!
I recently installed the latest version of zoneminder via ppa using master.
sudo add-apt-repository ppa:iconnor/zoneminder-master
sudo apt update
I'm having a problem with Montage Review. When installing zoneminder, I changed Apache to port 8084. I can enter the system but in montage review when viewing past videos it shows "No event". When opening the console I came across the following error:
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at http://ip/zm/api/frames/index/EventId:156/EventId:157/EventId:158/EventId:159/EventId:160/EventId:161.json?auth=f779bd0dd21bab269fbc88668f858a6a (reason: CORS request failed). Status code: (null).
There was an error js_logger-base-1713361024.js:91:11
    Error http://ip:8084/zm/cache/js_logger-base-1713361024.js:91
    error http://ip:8084/zm/cache/skins_classic_views_js_montagereview-base-1713361024.js:1213
    jQuery 4
Uncaught (in promise) undefined skins_classic_views_js_montagereview-base-1713361024.js:1213:19
    jQuery 4
 undefined skins_classic_views_js_montagereview-base-1713361024.js:220:15
Apparently an error in the event route that is trying to access the address with port 80 instead of 8084. In the API tab under Options it is enabled
In the log tab:
4/21/24, 6:06:04 PM GMT-3	web_js	344865	ERR	There was an error - error()	?view=montagereview&filtering=&MonitorName=&Source=&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=Archived&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=%3D&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bcnj%5D=and&filte	-
4/21/24, 6:03:00 PM GMT-3	web_js	339385	ERR	There was an error - error()	?view=montagereview
In Apache it was configured this way
/etc/apache2/conf-available/zoneminder.conf
<VirtualHost *:8084>
    # Configurações do ZoneMinder
        AllowOverride All
        Require all granted
    </Directory>
    # Alias e diretório para o cache do ZoneMinder
    Alias /zm/cache /var/cache/zoneminder/cache
    <Directory /var/cache/zoneminder/cache>
        AllowOverride None
        <IfModule mod_authz_core.c>
            Require all granted
        </IfModule>
    </Directory>
    # Alias e diretório para o diretório principal do ZoneMinder
        <IfModule mod_dir.c>
            DirectoryIndex index.php
        </IfModule>
    </Directory>
    # Configurações adicionais para API do ZoneMinder
        AllowOverride All
        RewriteEngine on
        RewriteBase /zm/api
        # Configurações de CORS
        Header set Access-Control-Allow-Origin "*"
        Header set Access-Control-Allow-Methods "GET, POST, OPTIONS"
        Header set Access-Control-Allow-Headers "Origin, X-Requested-With, Content-Type, Accept"
    </Directory>
        RewriteEngine on
        RewriteRule ^$ webroot/ [L]
        RewriteBase /zm/api
    </Directory>
        RewriteEngine On
        RewriteRule ^ index.php [L]
        RewriteBase /zm/api
    </Directory>
    <LocationMatch "^/zm/api/.*">
    </LocationMatch>
    <LocationMatch "^/zm/api/frames/index/EventId:\d+\.json$">
    </LocationMatch>
</VirtualHost>
in the file /etc/apache2/ports.conf I added the line at the end of the file: Listen 8084
