Annke I91BL not running
Posted: Tue May 07, 2024 3:04 am
I'm out of ideas here on how to get this device to show up in zm.
I enabled ONVIF but that didn't work, luckily I can stream it great using VLC and the following:
rtsp://USER:PW@IPADDR:554/H264/ch1/main/av_stream
I've been checking the settings in the camera config vs the zm settings and making sure they match 1:1
Other than the defaults from adding a new capture device and pasting the above path for source, the settings I changed were
modect
3840x2160
I tried method = "http tunnel" because another camera i'm running was set that way.
I tried setting the resolution to the lowest value the camera advertised and that didn't help either. Any suggestions would be greatly appreciated!
modect
3840x2160
