H264 Stream Failure in ZoneMinder, Works in VLC
Posted: Mon May 13, 2024 11:44 am
Hello ZoneMinder Community,
I'm facing an issue with an H264 stream in ZoneMinder that functions correctly when accessed via VLC. The stream URL is as follows:
'rtsp://xx.xx.xxx.xx:xxx/axis-media/media.amp?videocodec=h264&resolution=1920x1080
While trying to use this stream, I encounter the following error messages in the ZoneMinder logs:
Error Message 1:
Component: zmc_m2
PID: 539042
Level: ERR
Message: "Failed to prime capture of initial monitor"
File: zmc.cpp
Line: 263
Warning Message:
Component: zmc_m2
PID: 539042
Level: WAR
Message: "No width and height in video stream. Trying again"
File: zm_ffmpeg_camera.cpp
Line: 397
Additional details:
Source Type: Ffmpeg
Changing videocodec=jpeg in the URL resolves the issue, but I need to use H264.
Has anyone experienced a similar issue or have any suggestions on how to troubleshoot this? I am completely new to zoneminder. Any help would be greatly appreciated!
Thank you in advance for your assistance!
Error Message 1:
Component: zmc_m2
PID: 539042
Level: ERR
File: zmc.cpp
Line: 263
Warning Message:
Component: zmc_m2
PID: 539042
Level: WAR
Line: 397
Additional details:
Source Type: Ffmpeg
