Page 1 of 1
Problem when saving monitor config: 'Maximum Image Buffer Size' set to '0' zero
Posted: Thu May 16, 2024 12:30 pm
by DR_Omi
zoneminder (1.37.60~20240515114911-jammy)
mysql 8.1
Ubuntu 22.04.4
I found problem saving monitor config, when 'Maximum Image Buffer Size' is set to '0' zero (in doc it's described as unlimited)
I get info:
'Maximum Image Buffer Count should be greater then Pre event image count or else it cannot be satisfied.'
see attached screenshot
Re: Problem when saving monitor config: 'Maximum Image Buffer Size' set to '0' zero
Posted: Thu May 16, 2024 2:29 pm
by iconnor
Just pushed a fix. New packages building
Posted: Thu May 23, 2024 6:39 am
by DR_Omi
iconnor wrote: ↑Thu May 16, 2024 2:29 pm
Thank you, works perfect.
one more with buffers tab I found.
Setting "Maximum Image Buffer Size" to 0 (zero) the same happens with "Pre Event Image Count" (number -> 0)
and when I change "Pre Event Image Count" for example to 8 then "Maximum Image Buffer Size" is auto changed from 0 to 8
"Pre Event Image Count" <= "Maximum Image Buffer Size"
it cant be set "Pre Event Image Count" > 0 when "Maximum Image Buffer Size" is set to 0 (unlimited)
Posted: Thu May 23, 2024 5:54 pm
by iconnor
This should be corrected in todays build
Posted: Fri May 24, 2024 12:11 am
by dougmccrary
zoneminder:
Installed: 1.37.60~20240522143640-jammy
Candidate: 1.37.60~20240522143640-jammy
Version table:
*** 1.37.60~20240522143640-jammy 500
500
https://ppa.launchpadcontent.net/iconno ... ter/ubuntu jammy/main amd64 Packages
100 /var/lib/dpkg/status
1.37.60~20240523.219-jammy 500
500
http://zmrepo.zoneminder.com/debian/master jammy/ Packages
Posted: Mon May 27, 2024 1:22 pm
by DR_Omi
iconnor wrote: ↑Thu May 23, 2024 5:54 pm
I'm confused... in version 1.37.60~20240523140735-jammy problem with saving monitor config, when 'Maximum Image Buffer Size' is set to '0' zero (unlimited) is back.
Posted: Mon May 27, 2024 2:02 pm
by iconnor
Apparently I applied the fix to 1.36 but not to master.
New packages building.
