iOS zmNinja update
ajw_ca
iOS zmNinja update
Post by ajw_ca »
Hi. I have a zoneminder instance with a correctly configured ES server and I'm running zmNinja-pro on iOS.
The zmNinja logs and UI show alarm notifications being received, and the FCM tokens are being registered correctly on my Zoneminder server. However, I'm not getting any iOS style app notifications.
Is this because I'm using the old zmNinja-pro app does which does not communicate with the new FCM cloud function? I see the Android app has been updated, but I haven't seen a similar zmninja (non-pro) on the iOS App Store yet.
Cheers and thank you for all the work you guys do!
ajw_ca
Re: iOS zmNinja update
Post by ajw_ca »
Forgot to mention I'm running Zoneminder v1.36.33, ES v6.1.29 and the latest version of zmNinja-pro on iOS that was last updated 2 years ago.
Thank you!
nevermind19
Post by nevermind19 »
Same issue for me. ZmNinja pro in iPhone not send allarm from ES…i have tried into Android with last update All works. I don't know if they abandoned the project for IoS..
iamnotme
Post by iamnotme »
It’s a shame. I want to implement Zoneminder to move away from a proprietary solution.
Whilst Zoneminder works as I want it to it would be no use if ZMES isn’t working correctly to send notifications for events on iOS.
I'll take another stab at a new release soon.
