Trouble installing ZoneMinder on Ubuntu
Posted: Sun Jun 09, 2024 6:38 pm
Hello, when fully going through the steps of installing Zoneminder, I'm getting this error when trying to start it;
I tried this on a local pc running Ubuntu 24.04, suspecting incompatibility with this new version of Ubuntu, i tried on a Linode running 22.04 with the same result. I'm fairly novice and such, but i suspect part of the issue is that the repo you're told to add in all the tutorials i've found gives this output, mentioning '404' and it does not have a release file;
Here's the output of journalctl -xeu zoneminder.service
and systemctl status zoneminder.service
Again, as aformentioned, i'm novice. It's possible i'm doing something completely wrong. Thanks!
I've tried these tutorials,
https://www.how2shout.com/linux/how-to- ... 20-04-lts/
https://zoneminder.readthedocs.io/en/st ... 2-04-jammy
Job for zoneminder.service failed because the control process exited with error code.
See "systemctl status zoneminder.service" and "journalctl -xeu zoneminder.service" for details.
Adding repository.
Press [ENTER] to continue or Ctrl-c to cancel.
Found existing deb entry in /etc/apt/sources.list.d/iconnor-ubuntu-zoneminder-1_36-noble.sources
Hit:1 http://mirrors.linode.com/ubuntu noble InRelease
Hit:2 http://mirrors.linode.com/ubuntu noble-updates InRelease
Hit:3 http://mirrors.linode.com/ubuntu noble-backports InRelease
Hit:4 http://security.ubuntu.com/ubuntu noble-security InRelease
Ign:5 https://ppa.launchpadcontent.net/iconnor/zoneminder-1.36/ubuntu noble InRelease
Err:6 https://ppa.launchpadcontent.net/iconnor/zoneminder-1.36/ubuntu noble Release
404 Not Found [IP: 2620:2d:4000:1::81 443]
Reading package lists... Done
E: The repository 'https://ppa.launchpadcontent.net/iconnor/zoneminder-1.36/ubuntu noble Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
root@localhost:/home# sudo apt update && sudo apt upgrade
Starting zoneminder.service - ZoneMinder CCTV recording and surveillance system...
░░ Subject: A start job for unit zoneminder.service has begun execution
░░ Defined-By: systemd
░░ Support: http://www.ubuntu.com/support
░░ A start job for unit zoneminder.service has begun execution.
░░ The job identifier is 2584.
Jun 09 18:25:58 localhost zmpkg.pl[15605]: DBI connect('database=zm;host=localhost','zmuser',...) failed: Access denied for user 'zmuser'@'localhost' (using password: YES) at /usr/share/perl5/ZoneMinder/Database.pm line 110.
Jun 09 18:25:58 localhost zmpkg[15605]: ERR [Error reconnecting to db: errstr:Access denied for user 'zmuser'@'localhost' (using password: YES) error val:]
Jun 09 18:25:58 localhost zmpkg.pl[15605]: Unable to connect to DB. ZM Cannot continue.
Jun 09 18:25:58 localhost zmpkg.pl[15605]: BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Config.pm line 150.
Jun 09 18:25:58 localhost zmpkg.pl[15605]: Compilation failed in require at /usr/share/perl5/ZoneMinder.pm line 33.
Jun 09 18:25:58 localhost zmpkg.pl[15605]: BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder.pm line 33.
Jun 09 18:25:58 localhost zmpkg.pl[15605]: Compilation failed in require at /usr/bin/zmpkg.pl line 34.
Jun 09 18:25:58 localhost zmpkg.pl[15605]: BEGIN failed--compilation aborted at /usr/bin/zmpkg.pl line 34.
Jun 09 18:25:58 localhost systemd[1]: zoneminder.service: Control process exited, code=exited, status=255/EXCEPTION
░░ Subject: Unit process exited
░░ An ExecStart= process belonging to unit zoneminder.service has exited.
░░ The process' exit code is 'exited' and its exit status is 255.
Jun 09 18:25:58 localhost systemd[1]: zoneminder.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit zoneminder.service has entered the 'failed' state with result 'exit-code'.
Jun 09 18:25:58 localhost systemd[1]: Failed to start zoneminder.service - ZoneMinder CCTV recording and surveillance system.
░░ Subject: A start job for unit zoneminder.service has failed
░░ A start job for unit zoneminder.service has finished with a failure.
░░ The job identifier is 2584 and the job result is failed.
× zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/usr/lib/systemd/system/zoneminder.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Sun 2024-06-09 18:25:58 UTC; 8min ago
Docs: http://zoneminder.readthedocs.org/en/latest/
Process: 15605 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=255/EXCEPTION)
CPU: 96ms
