Dear all,
because of I do not find any solution within the forum I am writing this new topic.
I am using 1.37 with foscam cams and it worked very fine until yesterday.
As I had to setup up al cams new it does not work the same way as it used until before. Zoneminder is recording after motion, but it makes a very long film with sometimes nearly 10000 pictures. The logfiles do not report errors.
It works fine with a TL-SC3171 from TP-Link with the same config.
Has anybody an idea? Could anybody provide me with a link to a recomended configuration?
Thanks in advance.
Heimo
