SV3C camera calls china!
smp
Post by smp »
I decided to log the SV3C camera's network traffic, and to my horror I saw it calling home:
DST=47.94.5.121
POE cameras seem to be much better than managing analog equipment, at least for me.
I cannot afford commercial equipment, so I'm stuck with the china stuff.
My proposed solution:
  • Use dedicated Ubuntu box running Zoneminder
  • Attach POE switch to its NIC
  • Use old nvidia board attached to 65" tv via HDMI for local display thru local web-browser
  • No connection to the internet
Question:
Eventually I would like to be able to view cameras on other local devices, phone, etc. Could I safely place a second NIC in the box and use existing Ubuntu/linux SW to firewall off this 2nd NIC so that it CAN NOT be accessed by anything on the 1st NIC, ie. the cameras?
ILikeCelery67
Re: SV3C camera calls china!
Post by ILikeCelery67 »
You can block outgoing web traffic from your cams through the router firewall. This makes it so that your IP Cam cannot initiate communication with a remote IP, it will only respond to incoming traffic, which should only be the apps you are using to connect to the cams remotely. I had the same issue with a couple of my cameras. They don't "call home" anymore :)
smp
Post by smp »
I did that first thing. Problem is that both IP addresses and MAC addresses can be spoofed. I'm going for total isolation!
VARN
Post by VARN »
smp wrote: Mon Jun 24, 2024 2:17 pm Question:
This is pretty much how I have mine setup, my motherboard has a second NIC built in. I changed one of them to a different network, then changed the switch and cameras to match. I didn't bother configuring a firewall since if the camera did attempt to call home I doubt Ubuntu would bridge the networks on it's own. I've never actually monitored the traffic for the Amcrest cameras though.
