zmc crash since newer versions of june
6i6i
Post by 6i6i »
I got a problem, that zmc is crashing every time when a alarm is detected:
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [NULL Input buffer]
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [Got signal 11 (Segmentation fault), crashing]
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [Signal address is (nil), from 0x786a8e283a08]
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [Backtrace 0: /usr/bin/zmc(+0x8a202) [0x61079d47c202]]
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [Backtrace 1: /lib/x86_64-linux-gnu/libc.so.6(+0x42520) [0x786a8b442520]]
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [Backtrace 2: /lib/x86_64-linux-gnu/libjpeg.so.8(+0x44a08) [0x786a8e283a08]]
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [and execute the following command for more information:]
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [addr2line -Cfip -e /usr/bin/zmc 0x8a202]
This happens since version zoneminder:amd64 (1.37.61~20240611171544-jammy).
A downgrade to version zoneminder=1.37.61~20240611.106-jammy fixes the problem.
The crash does only happen for 2 of my 5 cameras. The 2 are very old Supra IPC 10A cams that use MJPEG:
Input #0, mpjpeg, from 'http://192.168.0.244/videostream.cgi?us ... n&pwd=1234':
Duration: N/A, bitrate: N/A
Stream #0:0: Video: mjpeg (Baseline), yuvj422p(pc, bt470bg/unknown/unknown), 640x480, 25 tbr, 25 tbn, 25 tbc
Re: zmc crash since newer versions of june
I believe I fixed this on the 28th. Please confirm that it is still affecting you with latest build.
6i6i
Post by 6i6i »
I have just switched to zoneminder/jammy,now 1.37.61~20240628094110-jammy amd64 [installed] and it still happens:
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [NULL Input buffer]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Got signal 11 (Segmentation fault), crashing]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Signal address is (nil), from 0x76f5a1121a08]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Backtrace 0: /usr/bin/zmc(+0x8a202) [0x61871d7d1202]]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Backtrace 1: /lib/x86_64-linux-gnu/libc.so.6(+0x42520) [0x76f59e242520]]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Backtrace 2: /lib/x86_64-linux-gnu/libjpeg.so.8(+0x44a08) [0x76f5a1121a08]]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [and execute the following command for more information:]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [addr2line -Cfip -e /usr/bin/zmc 0x8a202]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Got signal 6 (Aborted), crashing]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Signal address is 0x21002092e3, from 0x76f59e2969fc]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Backtrace 2: /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c) [0x76f59e2969fc]]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Backtrace 3: /lib/x86_64-linux-gnu/libc.so.6(raise+0x16) [0x76f59e242476]]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Backtrace 4: /lib/x86_64-linux-gnu/libc.so.6(abort+0xd3) [0x76f59e2287f3]]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(+0x89676) [0x76f59e289676]]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(+0xa0cfc) [0x76f59e2a0cfc]]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Backtrace 7: /lib/x86_64-linux-gnu/libc.so.6(+0xa2f16) [0x76f59e2a2f16]]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Backtrace 8: /lib/x86_64-linux-gnu/libc.so.6(+0xa56ad) [0x76f59e2a56ad]]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Backtrace 9: /lib/x86_64-linux-gnu/libc.so.6(+0x9494f) [0x76f59e29494f]]
Jul 03 13:51:55 server zmc_m4[2134755]: ERR [zmc_m4] [Backtrace 10: /lib/x86_64-linux-gnu/libc.so.6(+0x126850) [0x76f59e326850]]
