zmc crash since newer versions of june
Posted: Tue Jul 02, 2024 11:46 am
I got a problem, that zmc is crashing every time when a alarm is detected:
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [NULL Input buffer]
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [Got signal 11 (Segmentation fault), crashing]
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [Signal address is (nil), from 0x786a8e283a08]
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [Backtrace 0: /usr/bin/zmc(+0x8a202) [0x61079d47c202]]
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [Backtrace 1: /lib/x86_64-linux-gnu/libc.so.6(+0x42520) [0x786a8b442520]]
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [Backtrace 2: /lib/x86_64-linux-gnu/libjpeg.so.8(+0x44a08) [0x786a8e283a08]]
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [and execute the following command for more information:]
Jul 02 12:42:13 server zmc_m8[476790]: ERR [zmc_m8] [addr2line -Cfip -e /usr/bin/zmc 0x8a202]
This happens since version zoneminder:amd64 (1.37.61~20240611171544-jammy).
A downgrade to version zoneminder=1.37.61~20240611.106-jammy fixes the problem.
The crash does only happen for 2 of my 5 cameras. The 2 are very old Supra IPC 10A cams that use MJPEG:
Input #0, mpjpeg, from 'http://192.168.0.244/videostream.cgi?us ... n&pwd=1234':
Duration: N/A, bitrate: N/A
Stream #0:0: Video: mjpeg (Baseline), yuvj422p(pc, bt470bg/unknown/unknown), 640x480, 25 tbr, 25 tbn, 25 tbc
