Problems with server and zoneminder after 1.37.62 update
asunturd
Post by asunturd »
Hi All,
After the first 1.37.62 update the server logs(syslog/journal) grow indefenitely, zoneminder throws errors about not able to query or find monitors.
no change after updating to 1.37.62~20240707094607-jammy, which is current version installed
the monitors are showing in the database, somehow there is one extra monitor which is not showing in the gui, 5 and 6 are identical buy only 4 and 6 are showing in the gui
is there a way to rebuild the database or fix this somehow?
Jul 07 20:34:43 server zmdc[956]: ERR ['zmc -m 6' exited abnormally, exit status 255]
Jul 07 20:34:43 server zmc_m6[1234]: ERR [zmc_m6] [No monitors found]
Jul 07 20:34:43 server zmc_m6[1234]: ERR [zmc_m6] [Can't use query result: ]
Jul 07 20:34:43 server zmc_m6[1234]: ERR [zmc_m6] [Can't run query: SELECT `Id`, `Name`, `Deleted`, `ServerId`, `StorageId`, `Type`, `Capturing`+0, `Analysing`+0, `AnalysisSource`+0, `AnalysisImage`+0, `Recording`+0, `RecordingSource`+0, `Decoding`+0, `RTSP2WebEnabled`, `RTSP2WebType`, `JanusEnabled`, `JanusAudio>
Jul 07 20:34:41 server zmdc[956]: ERR ['zmc -m 6' exited abnormally, exit status 255]
Jul 07 20:34:41 server zmc_m6[1232]: ERR [zmc_m6] [No monitors found]
Jul 07 20:34:41 server zmc_m6[1232]: ERR [zmc_m6] [Can't use query result: ]
Jul 07 20:34:41 server zmc_m6[1232]: ERR [zmc_m6] [Can't run query: SELECT `Id`, `Name`, `Deleted`, `ServerId`, `StorageId`, `Type`, `Capturing`+0, `Analysing`+0, `AnalysisSource`+0, `AnalysisImage`+0, `Recording`+0, `RecordingSource`+0, `Decoding`+0, `RTSP2WebEnabled`, `RTSP2WebType`, `JanusEnabled`, `JanusAudio>
Jul 07 20:34:38 server zmdc[956]: ERR ['zmc -m 6' exited abnormally, exit status 255]
Jul 07 20:34:38 server zmc_m6[1102]: ERR [zmc_m6] [No monitors found]
Jul 07 20:34:38 server zmc_m6[1102]: ERR [zmc_m6] [Can't use query result: ]
Jul 07 20:34:38 server zmc_m6[1102]: ERR [zmc_m6] [Can't run query: SELECT `Id`, `Name`, `Deleted`, `ServerId`, `StorageId`, `Type`, `Capturing`+0, `Analysing`+0, `AnalysisSource`+0, `AnalysisImage`+0, `Recording`+0, `RecordingSource`+0, `Decoding`+0, `RTSP2WebEnabled`, `RTSP2WebType`, `JanusEnabled`, `JanusAudio>
mysql> SELECT * FROM Monitors;
| Id | Name         | Deleted | Notes | ServerId | StorageId | ManufacturerId | ModelId | Type   | Function | Capturing | Analysing | AnalysisSource | AnalysisImage | Recording | Enabled | DecodingEnabled | Decoding | RTSP2WebEnabled | RTSP2WebType | JanusEnabled | JanusAudioEnabled | Janus_Profile_Override | Janus_
Use_RTSP_Restream | Janus_RTSP_User | Janus_RTSP_Session_Timeout | LinkedMonitors | Triggers | EventStartCommand | EventEndCommand | ONVIF_URL | ONVIF_Events_Path | ONVIF_Username | ONVIF_Password | ONVIF_Options | ONVIF_Event_Listener | ONVIF_Alarm_Text | use_Amcrest_API | Device | Channel | Format | V4LMultiBuffer
 | V4LCapturesPerFrame | Protocol | Method  | Host | Port | SubPath | Path                                                            | SecondPath | Options | User     | Pass       | Width | Height | Colours | Palette | Orientation | Deinterlacing | Decoder | DecoderHWAccelName | DecoderHWAccelDevice | SaveJPEGs | V
ideoWriter | OutputCodec | Encoder | OutputContainer | EncoderParameters | RecordAudio | RecordingSource | RTSPDescribe | Brightness | Contrast | Hue | Colour | EventPrefix | LabelFormat | LabelX | LabelY | LabelSize | ImageBufferCount | MaxImageBufferCount | WarmupCount | PreEventCount | PostEventCount | StreamRepl
ayBuffer | AlarmFrameCount | SectionLength | SectionLengthWarn | EventCloseMode | MinSectionLength | FrameSkip | MotionFrameSkip | AnalysisFPSLimit | AnalysisUpdateDelay | MaxFPS | AlarmMaxFPS | FPSReportInterval | RefBlendPerc | AlarmRefBlendPerc | Controllable | ControlId | ControlDevice | ControlAddress | AutoSto
pTimeout | TrackMotion | TrackDelay | ReturnLocation | ReturnDelay | ModectDuringPTZ | DefaultRate | DefaultScale | DefaultCodec | SignalCheckPoints | SignalCheckColour | WebColour | Exif | Sequence | ZoneCount | Refresh | Latitude | Longitude | RTSPServer | RTSPStreamName | SOAP_wsa_compl | Importance | MQTT_Enable
d | MQTT_Subscriptions | StartupDelay |
|  4 | driveway-old |       0 |       |        0 |         3 |              9 |    NULL | Ffmpeg | Monitor  | None      | None      | Primary        | FullColour    | None      |       0 |               1 | Always   |               0 | HLS          |            0 |                 0 |                        |
                0 |            NULL |                          0 | NULL           |          |                   |                 |           |                   |                |                |               |                    0 |                  |               0 |        |       0 |      0 |           NULL
 |                   1 | NULL     | rtpRtsp | NULL |      |         | http://ip0/videostream.cgi?user=visitor&pwd=camera-pass | NULL       | NULL    |          |            |   640 |    480 |       4 |       0 | ROTATE_0    |             0 | auto    | NULL               | NULL                 |         0 |
         2 |           0 | auto    | NULL            |                   |           0 | Primary         |            0 |         -1 |       -1 |  -1 |     -1 | Event-      |             |      0 |      0 |         2 |                3 |                 121 |           0 |             5 |              5 |
       0 |               1 |           600 |                 0 | system         |               10 |         0 |               0 |             1.00 |                   0 |   NULL |        NULL |               100 |           12 |                12 |            0 |      NULL | NULL          | NULL           |
    NULL |           0 |       NULL |             -1 |        NULL |               0 |         100 |            0 | auto         |                 0 | #0000be           | #1b0986   |    0 |        1 |         1 |    NULL |     NULL |      NULL |          0 |                |              0 | Normal     |
0 |                    |            0 |
|  5 | driveway     |       1 |       |        0 |         3 |           NULL |    NULL | Ffmpeg | Monitor  | Always    | Always    | Primary        | FullColour    | OnMotion  |       0 |               1 | Always   |               0 | HLS          |            0 |                 0 |                        |
                0 |            NULL |                          0 | NULL           |          |                   |                 |           | /Events           |                |                |               |                    0 | MotionAlarm      |               0 |        |       0 |      0 |           NULL
 |                   1 | NULL     | rtpRtsp | NULL |      |         | rtsp://ip1:554/tcp_live/ch0_0                          | NULL       | NULL    | camera-user | camera-pass |  1280 |    720 |       4 |       0 | ROTATE_0    |             0 | auto    | NULL               | NULL                 |         0 |
    NULL |           0 |       NULL |             -1 |        NULL |               0 |         100 |            0 | auto         |                 0 | #0000be           | #b85d21   |    0 |        2 |         1 |    NULL |     NULL |      NULL |          0 |                |              0 | Normal     |
0 |                    |            0 |
|  6 | driveway     |       0 |       |        0 |         3 |           NULL |    NULL | Ffmpeg | Monitor  | Always    | Always    | Primary        | FullColour    | OnMotion  |       0 |               1 | Always   |               0 | HLS          |            0 |                 0 |                        |
         2 |           0 | auto    | NULL            |                   |           0 | Primary         |            0 |         -1 |       -1 |  -1 |     -1 | Event-      |             |      0 |      0 |         2 |                3 |                 121 |           0 |            10 |             10 |
       0 |               1 |           600 |                 0 | system         |               10 |         0 |               0 |             2.00 |                   0 |   NULL |        NULL |               100 |           12 |                12 |            0 |      NULL | NULL          | NULL           |
    NULL |           0 |       NULL |             -1 |        NULL |               0 |         100 |            0 | auto         |                 0 | #0000be           | #747200   |    0 |        3 |         1 |    NULL |     NULL |      NULL |          0 |                |              0 | Normal     |
0 |                    |            0 |
3 rows in set (0.01 sec)
Jul07205358.txt
(151.21 KiB) Downloaded 250 times
Re: Problems with server and zoneminder after 1.37.62 update
A second update should include the db update. If it doesn't automatically apply, do:
mysql -u zmuser -p zm < /usr/share/zoneminder/db/zm_update-1.37.62.sql
asunturd
Post by asunturd »
it did update the database when updating to .62 the first time, Im sure.
user@server:~$ mysql -u zmuser -p zm < /usr/share/zoneminder/db/zm_update-1.37.62.sql
Enter password:
Checking for WallClockTImestamps in Monitors
Monitor works now but GUI has no history of events, zero on everything
I tried "Force Alarm" but video does not get created:
Jul 08 08:48:24 server web_php[6834]: /video/6/2024-07-08/10453/incomplete.mp4: Invalid data found when processing input] at /usr/share/zoneminder/www/views/image.php line 349
Jul 08 08:48:24 server web_php[6834]: [mov,mp4,m4a,3gp,3g2,mj2 @ 0x55d3c9ddb680] moov atom not found
Jul 08 08:48:24 server web_php[6834]:   libpostproc    55.  9.100 / 55.  9.100
Jul 08 08:48:24 server web_php[6834]:   libswresample   3.  9.100 /  3.  9.100
Jul 08 08:48:24 server web_php[6834]:   libswscale      5.  9.100 /  5.  9.100
Jul 08 08:48:24 server web_php[6834]:   libavfilter     7.110.100 /  7.110.100
Jul 08 08:48:24 server web_php[6834]:   libavdevice    58. 13.100 / 58. 13.100
Jul 08 08:48:24 server web_php[6834]:   libavformat    58. 76.100 / 58. 76.100
Jul 08 08:48:24 server web_php[6834]:   libavcodec     58.134.100 / 58.134.100
Jul 08 08:48:24 server web_php[6834]:   libavutil      56. 70.100 / 56. 70.100
Jul 08 08:48:24 server web_php[6834]:   configuration: --prefix=/usr --extra-version=0ubuntu0.22.04.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio >
Jul 08 08:48:24 server web_php[6834]:   built with gcc 11 (Ubuntu 11.2.0-19ubuntu1)
Jul 08 08:48:24 server web_php[6834]:                   Output was: ffmpeg version 4.4.2-0ubuntu0.22.04.1 Copyright (c) 2000-2021 the FFmpeg developers
Jul 08 08:48:24 server web_php[6834]:                   Command was: /usr/bin/ffmpeg -ss 1 -i /video/6/2024-07-08/10453/incomplete.mp4 -frames:v 1 /video/6/2024-07-08/10453/snapshot.jpg 2>&1
Jul 08 08:48:24 server web_php[6834]: 7/8/24, 8:48:24 AM GMT+2.624974 web_php[6834].ERR [192.168.10.6] [Can't create frame images from video for this event incomplete.mp4
Jul 08 08:48:24 server web_php[6834]: 7/8/24, 8:48:24 AM GMT+2.451209 web_php[6834].WAR [192.168.10.6] [No frame found for event 10453] at /usr/share/zoneminder/www/views/image.php line 313
Jul 08 08:47:30 server web_php[6582]: /video/6/2024-07-08/10453/incomplete.mp4: Invalid data found when processing input] at /usr/share/zoneminder/www/views/image.php line 349
Jul 08 08:47:30 server web_php[6582]: [mov,mp4,m4a,3gp,3g2,mj2 @ 0x55d6ee4c9680] moov atom not found
Jul 08 08:47:30 server web_php[6582]:   libpostproc    55.  9.100 / 55.  9.100
Jul 08 08:47:30 server web_php[6582]:   libswresample   3.  9.100 /  3.  9.100
Jul 08 08:47:30 server web_php[6582]:   libswscale      5.  9.100 /  5.  9.100
Jul 08 08:47:30 server web_php[6582]:   libavfilter     7.110.100 /  7.110.100
Jul 08 08:47:30 server web_php[6582]:   libavdevice    58. 13.100 / 58. 13.100
Jul 08 08:47:30 server web_php[6582]:   libavformat    58. 76.100 / 58. 76.100
Jul 08 08:47:30 server web_php[6582]:   libavcodec     58.134.100 / 58.134.100
Jul 08 08:47:30 server web_php[6582]:   libavutil      56. 70.100 / 56. 70.100
Jul 08 08:47:30 server web_php[6582]:   configuration: --prefix=/usr --extra-version=0ubuntu0.22.04.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio >
Jul 08 08:47:30 server web_php[6582]:   built with gcc 11 (Ubuntu 11.2.0-19ubuntu1)
Jul 08 08:47:30 server web_php[6582]:                   Output was: ffmpeg version 4.4.2-0ubuntu0.22.04.1 Copyright (c) 2000-2021 the FFmpeg developers
Jul 08 08:47:30 server web_php[6582]:                   Command was: /usr/bin/ffmpeg -ss 1 -i /video/6/2024-07-08/10453/incomplete.mp4 -frames:v 1 /video/6/2024-07-08/10453/snapshot.jpg 2>&1
Jul 08 08:47:30 server web_php[6582]: 7/8/24, 8:47:30 AM GMT+2.203840 web_php[6582].ERR [192.168.10.6] [Can't create frame images from video for this event incomplete.mp4
Jul 08 08:47:30 server web_php[6582]: 7/8/24, 8:47:30 AM GMT+2.030332 web_php[6582].WAR [192.168.10.6] [No frame found for event 10453] at /usr/share/zoneminder/www/views/image.php line 313
Jul 08 08:45:01 server CRON[6852]: pam_unix(cron:session): session closed for user root
Jul 08 08:45:01 server CRON[6853]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Jul 08 08:45:01 server CRON[6852]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
Jul 08 08:43:13 server web_php[6582]: /video/6/2024-07-08/10453/incomplete.mp4: Invalid data found when processing input] at /usr/share/zoneminder/www/views/image.php line 349
Jul 08 08:43:13 server web_php[6582]: [mov,mp4,m4a,3gp,3g2,mj2 @ 0x55952e322680] moov atom not found
Jul 08 08:43:13 server web_php[6582]:   libpostproc    55.  9.100 / 55.  9.100
Jul 08 08:43:13 server web_php[6582]:   libswresample   3.  9.100 /  3.  9.100
Jul 08 08:43:13 server web_php[6582]:   libswscale      5.  9.100 /  5.  9.100
Jul 08 08:43:13 server web_php[6582]:   libavfilter     7.110.100 /  7.110.100
Jul 08 08:43:13 server web_php[6582]:   libavdevice    58. 13.100 / 58. 13.100
Jul 08 08:43:13 server web_php[6582]:   libavformat    58. 76.100 / 58. 76.100
Jul 08 08:43:13 server web_php[6582]:   libavcodec     58.134.100 / 58.134.100
Jul 08 08:43:13 server web_php[6582]:   libavutil      56. 70.100 / 56. 70.100
Jul 08 08:43:13 server web_php[6582]:   configuration: --prefix=/usr --extra-version=0ubuntu0.22.04.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio >
Jul 08 08:43:13 server web_php[6582]:   built with gcc 11 (Ubuntu 11.2.0-19ubuntu1)
Jul 08 08:43:13 server web_php[6582]:                   Output was: ffmpeg version 4.4.2-0ubuntu0.22.04.1 Copyright (c) 2000-2021 the FFmpeg developers
Jul 08 08:43:13 server web_php[6582]:                   Command was: /usr/bin/ffmpeg -ss 1 -i /video/6/2024-07-08/10453/incomplete.mp4 -frames:v 1 /video/6/2024-07-08/10453/snapshot.jpg 2>&1
Jul 08 08:43:13 server web_php[6582]: 7/8/24, 8:43:13 AM GMT+2.593546 web_php[6582].ERR [192.168.10.6] [Can't create frame images from video for this event incomplete.mp4
Jul 08 08:43:13 server web_php[6582]: 7/8/24, 8:43:13 AM GMT+2.429508 web_php[6582].WAR [192.168.10.6] [No frame found for event 10453] at /usr/share/zoneminder/www/views/image.php line 313
Jul 08 08:43:11 server web_php[6808]: 7/8/24, 8:43:11 AM GMT+2.421880 web_js[6808].ERR [192.168.10.6] [getCmdResponse%20stream%20error%3A%20socket_sendto(%20%2Frun%2Fzm%2Fzms-130942s.sock%20)%20failed%3A%20Connection%20refused%20-%20checkStreamForErrors()] at ?view=event&eid=10453&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bcnj%5D=and&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=M>
Jul 08 08:43:10 server web_php[6808]: 7/8/24, 8:43:10 AM GMT+2.937804 web_js[6808].ERR [192.168.10.6] [getCmdResponse%20stream%20error%3A%20socket_sendto(%20%2Frun%2Fzm%2Fzms-130942s.sock%20)%20failed%3A%20Connection%20refused%20-%20checkStreamForErrors()] at ?view=event&eid=10453&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bcnj%5D=and&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=M>
Jul 08 08:43:10 server web_php[6582]: 7/8/24, 8:43:10 AM GMT+2.924025 web_js[6582].ERR [192.168.10.6] [getCmdResponse%20stream%20error%3A%20socket_sendto(%20%2Frun%2Fzm%2Fzms-130942s.sock%20)%20failed%3A%20Connection%20refused%20-%20checkStreamForErrors()] at ?view=event&eid=10453&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bcnj%5D=and&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=M>
Jul 08 08:43:10 server zms_e10453[6827]: FAT [zms_e10453] [JPEGS not saved. zms is not capable of streaming jpegs from mp4 yet]
Jul 08 08:43:10 server zms_e10453[6827]: WAR [zms_e10453] [Unable to open ffmpeg_input /video/6/2024-07-08/10453/incomplete.mp4]
Jul 08 08:43:10 server zms_e10453[6827]: ERR [zms_e10453] [Could not open input file '/video/6/2024-07-08/10453/incomplete.mp4' (error 'Invalid data found when processing input')]
Jul 08 08:42:52 server web_php[6491]: 7/8/24, 8:42:52 AM GMT+2.439243 web_js[6491].ERR [192.168.10.6] [getCmdResponse%20stream%20error%3A%20socket_sendto(%20%2Frun%2Fzm%2Fzms-784510s.sock%20)%20failed%3A%20Connection%20refused%20-%20checkStreamForErrors()] at ?view=event&eid=10453&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bcnj%5D=and&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=M>
Jul 08 08:42:51 server web_php[6491]: 7/8/24, 8:42:51 AM GMT+2.942432 web_js[6491].ERR [192.168.10.6] [getCmdResponse%20stream%20error%3A%20socket_sendto(%20%2Frun%2Fzm%2Fzms-784510s.sock%20)%20failed%3A%20Connection%20refused%20-%20checkStreamForErrors()] at ?view=event&eid=10453&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bcnj%5D=and&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=M>
Jul 08 08:42:51 server web_php[6742]: 7/8/24, 8:42:51 AM GMT+2.940170 web_js[6742].ERR [192.168.10.6] [getCmdResponse%20stream%20error%3A%20socket_sendto(%20%2Frun%2Fzm%2Fzms-784510s.sock%20)%20failed%3A%20Connection%20refused%20-%20checkStreamForErrors()] at ?view=event&eid=10453&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bcnj%5D=and&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=M>
Jul 08 08:42:51 server zms_e10453[6800]: FAT [zms_e10453] [JPEGS not saved. zms is not capable of streaming jpegs from mp4 yet]
Jul 08 08:42:51 server zms_e10453[6800]: WAR [zms_e10453] [Unable to open ffmpeg_input /video/6/2024-07-08/10453/incomplete.mp4]
Jul 08 08:42:51 server zms_e10453[6800]: ERR [zms_e10453] [Could not open input file '/video/6/2024-07-08/10453/incomplete.mp4' (error 'Invalid data found when processing input')]
Jul 08 08:42:51 server web_php[6495]: /video/6/2024-07-08/10453/incomplete.mp4: Invalid data found when processing input] at /usr/share/zoneminder/www/views/image.php line 349
Jul 08 08:42:51 server web_php[6495]: [mov,mp4,m4a,3gp,3g2,mj2 @ 0x56409c3ca680] moov atom not found
asunturd
Post by asunturd »
Ok, I've tried again with "Forced Alarm" and now the video is created but there still are errors in the logs, see attachment please.
I must add that Im using tunneled ssh connection to view web-gui at this time.
2024-07-08 095635.jpg (260.24 KiB) Viewed 4814 times
