Mysql help - DB corrupted?
alabamatoy
Post by alabamatoy »
1.37.62 on Ubuntu 22.04
Mysql has crashed and wont restart, obviously this blocks ZM from running. I frankly dont care about the data, I can recreate all of it manually...PITA, but I can do it. But I cannot get mysql to start. I set
[mysqld]
innodb_force_recovery = 3
in /etc/mysql/mysql.conf.d Here's what I get when I attempt to start mysql:
2024-07-10T22:36:20.131292Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.37-0ubuntu0.22.04.3) starting as process 294596
2024-07-10T22:36:20.146629Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2024-07-10T22:36:20.839540Z 0 [ERROR] [MY-012153] [InnoDB] Trying to access page number 3321888767 in space 4294967278, space name innodb_undo_002, which is outside the tablespace bounds. Byte offset 0, len 16384, i/o type read. If you get this error at mysqld startup, please check that your my.cnf matches the ibdata files that you have in the MySQL server.
2024-07-10T22:36:20.839612Z 0 [ERROR] [MY-012154] [InnoDB] Server exits.
2024-07-10T22:36:20.839628Z 0 [ERROR] [MY-013183] [InnoDB] Assertion failure: fil0fil.cc:7525 thread 137293995247168
InnoDB: We intentionally generate a memory trap.
InnoDB: Submit a detailed bug report to http://bugs.mysql.com.
InnoDB: If you get repeated assertion failures or crashes, even
InnoDB: immediately after the mysqld startup, there may be
InnoDB: corruption in the InnoDB tablespace. Please refer to
InnoDB: http://dev.mysql.com/doc/refman/8.0/en/forcing-innodb-recovery.html
InnoDB: about forcing recovery.
2024-07-10T22:36:20Z UTC - mysqld got signal 6 ;
Most likely, you have hit a bug, but this error can also be caused by malfunctioning hardware.
BuildID[sha1]=9e65b9e0a7de4a17ad5002e0653e3f1a1aa060dd
Thread pointer: 0x0
Attempting backtrace. You can use the following information to find out
where mysqld died. If you see no messages after this, something went
terribly wrong...
stack_bottom = 0 thread_stack 0x100000
/usr/sbin/mysqld(my_print_stacktrace(unsigned char const*, unsigned long)+0x41) [0x5d4c7166fab1]
/usr/sbin/mysqld(print_fatal_signal(int)+0x3bc) [0x5d4c70c7cfac]
/usr/sbin/mysqld(my_server_abort()+0x7e) [0x5d4c70c7d0de]
/usr/sbin/mysqld(my_abort()+0xe) [0x5d4c71669e4e]
/usr/sbin/mysqld(ut_dbg_assertion_failed(char const*, char const*, unsigned long)+0x183) [0x5d4c71825593]
/usr/sbin/mysqld(+0x1dfe578) [0x5d4c71e7e578]
/usr/sbin/mysqld(Fil_shard::do_io(IORequest const&, bool, page_id_t const&, page_size_t const&, unsigned long, unsigned long, void*, void*)+0xcbb) [0x5d4c71931f7b]
/usr/sbin/mysqld(fil_io(IORequest const&, bool, page_id_t const&, page_size_t const&, unsigned long, unsigned long, void*, void*)+0x86) [0x5d4c71932026]
/usr/sbin/mysqld(buf_read_page_low(dberr_t*, bool, unsigned long, unsigned long, page_id_t const&, page_size_t const&, bool)+0x169) [0x5d4c71889fb9]
/usr/sbin/mysqld(buf_read_page(page_id_t const&, page_size_t const&)+0x4a) [0x5d4c7188affa]
/usr/sbin/mysqld(+0x180b102) [0x5d4c7188b102]
/usr/sbin/mysqld(Buf_fetch_normal::get(buf_block_t*&)+0x420) [0x5d4c71852a50]
/usr/sbin/mysqld(buf_page_get_gen(page_id_t const&, page_size_t const&, unsigned long, buf_block_t*, Page_fetch, ut::Location, mtr_t*, bool)+0x85a) [0x5d4c71853f8a]
/usr/sbin/mysqld(trx_undo_lists_init(trx_rseg_t*)+0x248) [0x5d4c7182a828]
/usr/sbin/mysqld(trx_rseg_init_thread(void*, unsigned long)+0xbf) [0x5d4c717ff06f]
/usr/sbin/mysqld(+0x1777ffd) [0x5d4c717f7ffd]
/lib/x86_64-linux-gnu/libstdc++.so.6(+0xdc253) [0x7cde6bcdc253]
/lib/x86_64-linux-gnu/libc.so.6(+0x94ac3) [0x7cde6b894ac3]
/lib/x86_64-linux-gnu/libc.so.6(+0x126850) [0x7cde6b926850]
I see that it tells me "please check that your my.cnf matches the ibdata files that you have in the MySQL server." I do not understand how to do this. /var/lib/mysql has lots of files related to ibdata, but I dont understand how to "match" anything with my.cnf.
Nothing else that I know of is using mysql on this server, so if I blow it away and start over, I dont care.
How do I fix this?
Re: Mysql help - DB corrupted?
I have almost never had any success with recover < 6. Try 6. It will be read only, but you can take a db dump.
Dropping the existing db gets hard when everything is read only. I typically apt remove --purge mysql* in order to nuke it from orbit, then re-install, and restore from backup.
alabamatoy
OK, with recover set at 6, here's what I get:
2024-07-11T13:44:59.270788Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.37-0ubuntu0.22.04.3) starting as process 319111
2024-07-11T13:44:59.272325Z 0 [System] [MY-013951] [Server] A backtrace was processed and added to the main error-log in the appropriate format.
2024-07-11T13:44:59.285934Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2024-07-11T13:44:59.461508Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
2024-07-11T13:44:59.499367Z 1 [Warning] [MY-011018] [InnoDB] Skip updating information_schema metadata in InnoDB read-only mode.
2024-07-11T13:44:59.499380Z 1 [Warning] [MY-010005] [Server] Skip re-populating collations and character sets tables in InnoDB read-only mode.
2024-07-11T13:44:59.500986Z 0 [ERROR] [MY-011300] [Server] Plugin mysqlx reported: 'Setup of socket: '/var/run/mysqld/mysqlx.sock' failed, can't create lock file /var/run/mysqld/mysqlx.sock.lock'
2024-07-11T13:44:59.501127Z 2 [Warning] [MY-011018] [Server] Skip updating information_schema metadata in InnoDB read-only mode.
2024-07-11T13:44:59.501424Z 0 [Warning] [MY-010970] [Server] Skipped updating resource group metadata in InnoDB read only mode.
2024-07-11T13:44:59.501431Z 0 [Warning] [MY-010970] [Server] Skipped updating resource group metadata in InnoDB read only mode.
2024-07-11T13:44:59.580478Z 0 [Warning] [MY-010068] [Server] CA certificate ca.pem is self signed.
2024-07-11T13:44:59.580535Z 0 [System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel.
2024-07-11T13:44:59.585822Z 0 [ERROR] [MY-010273] [Server] Could not create unix socket lock file /var/run/mysqld/mysqld.sock.lock.
2024-07-11T13:44:59.585832Z 0 [ERROR] [MY-010268] [Server] Unable to setup unix socket lock file.
2024-07-11T13:44:59.585839Z 0 [ERROR] [MY-010119] [Server] Aborting
2024-07-11T13:45:00.117848Z 0 [System] [MY-010910] [Server] /usr/sbin/mysqld: Shutdown complete (mysqld 8.0.37-0ubuntu0.22.04.3)  (Ubuntu).
Attempting to start the DB server after commenting out the recover setting results in the same error as before.
what is the secret to mysqldump when the server wont run?
This is the key line here. What is wrong with /var/run/mysqld/mysqld.sock.lock. ? Maybe you need to delete it.
alabamatoy
OK. I ripped it all out and started over. apt remove zoneminder --purge and do it all over again.
apt install zoneminder
errors with
Detected db service is mysql.service
mysql.service is a disabled or a static unit, not starting it.
NOTE: MySQL/MariaDB not running; please start mysql and run dpkg-reconfigure zoneminder when it is running.
So I stated mysql (no errors) and tried dpk-reconfigure zoneminder and got
Checking for db
mysqladmin: connect to server at 'localhost' failed
error: 'Access denied for user 'debian-sys-maint'@'localhost' (using password: YES)'
Cannot talk to database. You will have to create the db manually with something like:
So there is no use "debian-sys-maint", nor is there a "zmuser" so something went off the rails.
Any suggestions?
look in /var/lib/mysql and /etc/mysql and remove anything found (or move out of the way).
apt install mysql-server (or mariadb)
alabamatoy
iconnor wrote: Sun Jul 14, 2024 9:36 pm apt remove --purge mysql*
OK, so I ripped it all out and reinstalled IAW these instructions. I saw no errors during installation. And now, "systemctl status zoneminder" and same for mysql and apache2 show all 3 are running. But apparently the connection between ZM and apache2 was not made, as https://servername/zm returns error 404 not found. /usr/share/zoneminder/www is owned by root/root when I would expect it to be owned by wwwdata......right?
I listed the apache2 enabled mods and the cgi mod is in fact enabled. zoneminder.conf is listed in conf-available but not in conf-enabled (that stuff is quite confusing to me, dont really grok it). Is this the issue?
Almost, but not quite there, it would seem....
bellabrownbe wrote: Wed Jul 17, 2024 3:08 am How do you manage to recover a MySQL database using a method other than recover < 6 when the database is in read-only mode, and what steps do you take to completely remove and re-install MySQL to restore from a backup?
retro bowl college
While ZM employs mysql (and potentially other similar DB type tools) these kinds of questions are somewhat off-azimuth for a Zoneminder forum. That said, links to such how-tos probably would be a good addition to the ZM wiki, which largely leaves one to ones own devices for such insight. See https://wiki.zoneminder.com/Backups
zoneminder.conf has to be in conf-enabled. Running sudo a2enconf zoneminder creates a soft link to the file in conf-available.
alabamatoy
iconnor wrote: Wed Jul 17, 2024 2:38 pm zoneminder.conf has to be in conf-enabled. Running sudo a2enconf zoneminder creates a soft link to the file in conf-available.
Bingo....ZM is accessible from port 443.....As always, Isaac, thanks so much for your patient assistance.
