Segmentation fault
Anna.N
Segmentation fault
Post by Anna.N »
With the latest update (1.37.63~20240719.43) I get the following message every minute and the live view is frozen
Got signal 11 (Segmentation fault), crashing	zm_signal.cpp	54
'zmc -m 2' exited abnormally, exit status 255	zmdc.pl
MarsRover
Re: Segmentation fault
Post by MarsRover »
Same experience, had to revert to 1.37.63~20240715.8-focal amd64
All zmc processes were almost instantly and constantly crashing with segfaults on 1.37.63~20240719144459-focal amd64
lightguy48
Post by lightguy48 »
Me too... completely dead in the water... trying to roll back
lightguy48
So I managed to roll back to 1.37.62 which seems to have partially restored normal operation but I'm having a new issues where nph-zms will chew up all my memory and bog down the system.
I eventually have to restart apache2 to get the system back. I'm not sure if it's related to my rollback or something else...
tyronesluck
Post by tyronesluck »
Same here, dont know if I feel like reverting to an older version if an update will come soon.
asknight
Post by asknight »
I'm here to join the club. I have ran through all settings and can't escape the seg fault. What's the easiest way to roll back to the prior 1.37.63? I can't seem to find it on the release now.
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Got signal 11 (Segmentation fault), crashing]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Signal address is 0x87, from 0x5e719769d3a8]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace 0: /usr/bin/zmc(+0x92549) [0x5e71976ae549]]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace 1: /lib/x86_64-linux-gnu/libc.so.6(+0x45320) [0x754301645320]]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace 2: /usr/bin/zmc(+0x813a8) [0x5e719769d3a8]]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace 3: /usr/bin/zmc(+0x4b3c5) [0x5e71976673c5]]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace 4: /usr/bin/zmc(+0x1057e1) [0x5e71977217e1]]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace 5: /lib/x86_64-linux-gnu/libstdc++.so.6(+0xeabb4) [0x754301aeabb4]]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(+0x9ca94) [0x75430169ca94]]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace 7: /lib/x86_64-linux-gnu/libc.so.6(+0x129c3c) [0x754301729c3c]]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [and execute the following command for more information:]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [addr2line -Cfip -e /usr/bin/zmc 0x92549 0x813a8 0x4b3c5 0x1057e1]
(base) ak@cyka-blyat:/dev/dri$ addr2line -Cfip -e /usr/bin/zmc 0x92549 0x813a8 0x4b3c5 0x1057e1
addr2line: DWARF error: unable to read alt ref 9324
addr2line: DWARF error: unable to read alt ref 48558
addr2line: DWARF error: unable to read alt ref 626637
addr2line: DWARF error: unable to read alt ref 712554
addr2line: DWARF error: unable to read alt ref 1045355
addr2line: DWARF error: unable to read alt ref 973289
addr2line: DWARF error: unable to read alt ref 152567
addr2line: DWARF error: unable to read alt ref 1441928
addr2line: DWARF error: unable to read alt ref 1389735
addr2line: DWARF error: unable to read alt ref 1700393
addr2line: DWARF error: unable to read alt ref 1858508
addr2line: DWARF error: unable to read alt ref 324329
addr2line: DWARF error: unable to read alt ref 2095651
addr2line: DWARF error: unable to read alt ref 2179688
addr2line: DWARF error: unable to read alt ref 2488529
addr2line: DWARF error: unable to read alt ref 2920847
addr2line: DWARF error: unable to read alt ref 2911435
addr2line: DWARF error: unable to read alt ref 2899742
addr2line: DWARF error: unable to read alt ref 2899637
addr2line: DWARF error: unable to read alt ref 2899518
addr2line: DWARF error: unable to read alt ref 2899381
addr2line: DWARF error: unable to read alt ref 2889891
addr2line: DWARF error: unable to read alt ref 2869361
addr2line: DWARF error: unable to read alt ref 2847003
addr2line: DWARF error: unable to read alt ref 2834971
addr2line: DWARF error: unable to read alt ref 2724651
addr2line: DWARF error: unable to read alt ref 2997335
addr2line: DWARF error: unable to read alt ref 3377130
addr2line: DWARF error: unable to read alt ref 3560537
addr2line: DWARF error: unable to read alt ref 512394
addr2line: DWARF error: unable to read alt ref 688621
addr2line: DWARF error: unable to read alt ref 2740679
addr2line: DWARF error: unable to read alt ref 618418
addr2line: DWARF error: unable to read alt ref 4256798
addr2line: DWARF error: unable to read alt ref 2822698
addr2line: DWARF error: unable to read alt ref 1396600
addr2line: DWARF error: unable to read alt ref 1482131
addr2line: DWARF error: unable to read alt ref 234808
addr2line: DWARF error: unable to read alt ref 1178129
zm_die_handler(int, siginfo_t*, void*) at ??:?
PacketQueue::clearPackets(std::shared_ptr<ZMPacket> const&) at :?
Monitor::Analyse() at :?
AnalysisThread::Run() at ??:?
Anna.N
Post by Anna.N »
If you are running debian it shoud be sufficient to roll back to 1.37.63~20240716.38-bookworm
 sudo apt install zoneminder=1.37.63~20240716.38-bookworm
JBE-Zorg
Post by JBE-Zorg »
Same issue here on Ubuntu 24.04, seg faults. Downgraded to 1.37.63~20240716.38. So far, running normally again.
07/21/24 09:18:59.809324 zmc_m1[50620].ERR-zm_signal.cpp/54 [Got signal 11 (Segmentation fault), crashing]
07/21/24 09:18:59.809363 zmc_m1[50620].ERR-zm_signal.cpp/86 [Signal address is 0xa7, from 0x56133920b768]
07/21/24 09:18:59.809622 zmc_m1[50620].ERR-zm_signal.cpp/112 [Backtrace 0: /usr/bin/zmc(+0x8a4d9) [0x56133921f4d9]]
07/21/24 09:18:59.809628 zmc_m1[50620].ERR-zm_signal.cpp/112 [Backtrace 1: /lib/x86_64-linux-gnu/libc.so.6(+0x42520) [0x7efeeacdf520]]
07/21/24 09:18:59.809635 zmc_m1[50620].ERR-zm_signal.cpp/112 [Backtrace 2: /usr/bin/zmc(+0x76768) [0x56133920b768]]
07/21/24 09:18:59.809638 zmc_m1[50620].ERR-zm_signal.cpp/112 [Backtrace 3: /usr/bin/zmc(+0x47ce3) [0x5613391dcce3]]
07/21/24 09:18:59.809641 zmc_m1[50620].ERR-zm_signal.cpp/112 [Backtrace 4: /usr/bin/zmc(+0xfd9e1) [0x5613392929e1]]
07/21/24 09:18:59.809643 zmc_m1[50620].ERR-zm_signal.cpp/112 [Backtrace 5: /lib/x86_64-linux-gnu/libstdc++.so.6(+0xdc253) [0x7efeeb0ab253]]
07/21/24 09:18:59.809646 zmc_m1[50620].ERR-zm_signal.cpp/112 [Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(+0x94ac3) [0x7efeead31ac3]]
07/21/24 09:18:59.809648 zmc_m1[50620].ERR-zm_signal.cpp/112 [Backtrace 7: /lib/x86_64-linux-gnu/libc.so.6(+0x126850) [0x7efeeadc3850]]
07/21/24 09:18:59.809651 zmc_m1[50620].ERR-zm_signal.cpp/131 [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
07/21/24 09:18:59.809654 zmc_m1[50620].ERR-zm_signal.cpp/132 [and execute the following command for more information:]
07/21/24 09:18:59.809656 zmc_m1[50620].ERR-zm_signal.cpp/133 [addr2line -Cfip -e /usr/bin/zmc 0x8a4d9 0x76768 0x47ce3 0xfd9e1]
addr2line: DWARF error: unable to read alt ref 10615
addr2line: DWARF error: unable to read alt ref 49443
addr2line: DWARF error: could not find variable specification at offset 0xb79a
addr2line: DWARF error: could not find variable specification at offset 0xe85
addr2line: DWARF error: unable to read alt ref 254272
addr2line: DWARF error: unable to read alt ref 1166078
addr2line: DWARF error: could not find variable specification at offset 0xe6145
addr2line: DWARF error: could not find variable specification at offset 0x102f6
addr2line: DWARF error: could not find variable specification at offset 0x101f7
addr2line: DWARF error: unable to read alt ref 255667
addr2line: DWARF error: unable to read alt ref 129712
addr2line: DWARF error: unable to read alt ref 4205782
addr2line: DWARF error: unable to read alt ref 262983
addr2line: DWARF error: unable to read alt ref 261360
addr2line: DWARF error: unable to read alt ref 200949
addr2line: DWARF error: unable to read alt ref 1135358
addr2line: DWARF error: unable to read alt ref 1269
addr2line: DWARF error: unable to read alt ref 105558
addr2line: DWARF error: unable to read alt ref 169180
Monitor::Analyse() at ./dbuild/src/./src/zm_monitor.cpp:2551
asknight
Post by asknight »
Anna.N wrote: Sun Jul 21, 2024 10:42 am If you are running debian it shoud be sufficient to roll back to 1.37.63~20240716.38-bookworm
The relevant package is no longer in noble. Only jammy, and it complains loudly of tons of broken dependencies when it's tried to be forced.
https://ppa.launchpadcontent.net/iconnor/zoneminder-master/ubuntu/dists/noble/main/binary-amd64/
MarsRover
Post by MarsRover »
asknight wrote: Mon Jul 22, 2024 3:46 am The relevant package is no longer in noble. Only jammy, and it complains loudly of tons of broken dependencies when it's tried to be forced.
You may look here, debs for last 8 builds are available
https://launchpad.net/~iconnor/+archive ... lter=noble
asknight
Post by asknight »
MarsRover wrote: Mon Jul 22, 2024 8:43 am
You are AWESOME and I can't thank you enough. I beat my keyboard to death the other night trying to locate that archive. It's now bookmarked in multiple locations, lol. Thanks again!
MarsRover
Post by MarsRover »
I noticed that there's a new build 1.37.63~20240723103852 pushed to Ubuntu repo
Did anyone try it already, what about those segfaults, still there?
Anna.N
Post by Anna.N »
I tried zoneminder_1.37.63~20240723.45-bookworm. Seems to run without problems
hans109h
Post by hans109h »
MarsRover wrote: Tue Jul 23, 2024 8:59 pm I noticed that there's a new build 1.37.63~20240723103852 pushed to Ubuntu repo
I tried this on 24.04 and still had the segmentation faults, I'm stable on the 20240716 version.
Hans
bfl
Post by bfl »
1.37.63~20240723103852-jammy - no segfaults. Everything looks fine :D.
