Page 1 of 2
Segmentation fault
Posted: Sat Jul 20, 2024 9:54 am
by Anna.N
With the latest update (1.37.63~20240719.43) I get the following message every minute and the live view is frozen
Got signal 11 (Segmentation fault), crashing zm_signal.cpp 54
'zmc -m 2' exited abnormally, exit status 255 zmdc.pl
Re: Segmentation fault
Posted: Sat Jul 20, 2024 4:04 pm
by MarsRover
Same experience, had to revert to 1.37.63~20240715.8-focal amd64
All zmc processes were almost instantly and constantly crashing with segfaults on 1.37.63~20240719144459-focal amd64
Posted: Sun Jul 21, 2024 2:50 am
by lightguy48
Me too... completely dead in the water... trying to roll back
Posted: Sun Jul 21, 2024 3:42 am
by lightguy48
So I managed to roll back to 1.37.62 which seems to have partially restored normal operation but I'm having a new issues where nph-zms will chew up all my memory and bog down the system.
I eventually have to restart apache2 to get the system back. I'm not sure if it's related to my rollback or something else...
Posted: Sun Jul 21, 2024 7:44 am
by tyronesluck
Same here, dont know if I feel like reverting to an older version if an update will come soon.
Posted: Sun Jul 21, 2024 7:53 am
by asknight
I'm here to join the club. I have ran through all settings and can't escape the seg fault. What's the easiest way to roll back to the prior 1.37.63? I can't seem to find it on the release now.
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Got signal 11 (Segmentation fault), crashing]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Signal address is 0x87, from 0x5e719769d3a8]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace 0: /usr/bin/zmc(+0x92549) [0x5e71976ae549]]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace 1: /lib/x86_64-linux-gnu/libc.so.6(+0x45320) [0x754301645320]]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace 2: /usr/bin/zmc(+0x813a8) [0x5e719769d3a8]]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace 3: /usr/bin/zmc(+0x4b3c5) [0x5e71976673c5]]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace 4: /usr/bin/zmc(+0x1057e1) [0x5e71977217e1]]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace 5: /lib/x86_64-linux-gnu/libstdc++.so.6(+0xeabb4) [0x754301aeabb4]]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(+0x9ca94) [0x75430169ca94]]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace 7: /lib/x86_64-linux-gnu/libc.so.6(+0x129c3c) [0x754301729c3c]]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [and execute the following command for more information:]
Jul 21 03:04:58 cyka-blyat zmc_m1[1390350]: ERR [zmc_m1] [addr2line -Cfip -e /usr/bin/zmc 0x92549 0x813a8 0x4b3c5 0x1057e1]
(base) ak@cyka-blyat:/dev/dri$ addr2line -Cfip -e /usr/bin/zmc 0x92549 0x813a8 0x4b3c5 0x1057e1
addr2line: DWARF error: unable to read alt ref 9324
addr2line: DWARF error: unable to read alt ref 48558
addr2line: DWARF error: unable to read alt ref 626637
addr2line: DWARF error: unable to read alt ref 712554
addr2line: DWARF error: unable to read alt ref 1045355
addr2line: DWARF error: unable to read alt ref 973289
addr2line: DWARF error: unable to read alt ref 152567
addr2line: DWARF error: unable to read alt ref 1441928
addr2line: DWARF error: unable to read alt ref 1389735
addr2line: DWARF error: unable to read alt ref 1700393
addr2line: DWARF error: unable to read alt ref 1858508
addr2line: DWARF error: unable to read alt ref 324329
addr2line: DWARF error: unable to read alt ref 2095651
addr2line: DWARF error: unable to read alt ref 2179688
addr2line: DWARF error: unable to read alt ref 2488529
addr2line: DWARF error: unable to read alt ref 2920847
addr2line: DWARF error: unable to read alt ref 2911435
addr2line: DWARF error: unable to read alt ref 2899742
addr2line: DWARF error: unable to read alt ref 2899637
addr2line: DWARF error: unable to read alt ref 2899518
addr2line: DWARF error: unable to read alt ref 2899381
addr2line: DWARF error: unable to read alt ref 2889891
addr2line: DWARF error: unable to read alt ref 2869361
addr2line: DWARF error: unable to read alt ref 2847003
addr2line: DWARF error: unable to read alt ref 2834971
addr2line: DWARF error: unable to read alt ref 2724651
addr2line: DWARF error: unable to read alt ref 2997335
addr2line: DWARF error: unable to read alt ref 3377130
addr2line: DWARF error: unable to read alt ref 3560537
addr2line: DWARF error: unable to read alt ref 512394
addr2line: DWARF error: unable to read alt ref 688621
addr2line: DWARF error: unable to read alt ref 2740679
addr2line: DWARF error: unable to read alt ref 618418
addr2line: DWARF error: unable to read alt ref 4256798
addr2line: DWARF error: unable to read alt ref 2822698
addr2line: DWARF error: unable to read alt ref 1396600
addr2line: DWARF error: unable to read alt ref 1482131
addr2line: DWARF error: unable to read alt ref 234808
addr2line: DWARF error: unable to read alt ref 1178129
zm_die_handler(int, siginfo_t*, void*) at ??:?
PacketQueue::clearPackets(std::shared_ptr<ZMPacket> const&) at :?
Monitor::Analyse() at :?
AnalysisThread::Run() at ??:?
Posted: Sun Jul 21, 2024 10:42 am
by Anna.N
If you are running debian it shoud be sufficient to roll back to 1.37.63~20240716.38-bookworm
sudo apt install zoneminder=1.37.63~20240716.38-bookworm
Posted: Sun Jul 21, 2024 4:08 pm
by JBE-Zorg
Same issue here on Ubuntu 24.04, seg faults. Downgraded to 1.37.63~20240716.38. So far, running normally again.
07/21/24 09:18:59.809324 zmc_m1[50620].ERR-zm_signal.cpp/54 [Got signal 11 (Segmentation fault), crashing]
07/21/24 09:18:59.809363 zmc_m1[50620].ERR-zm_signal.cpp/86 [Signal address is 0xa7, from 0x56133920b768]
07/21/24 09:18:59.809622 zmc_m1[50620].ERR-zm_signal.cpp/112 [Backtrace 0: /usr/bin/zmc(+0x8a4d9) [0x56133921f4d9]]
07/21/24 09:18:59.809628 zmc_m1[50620].ERR-zm_signal.cpp/112 [Backtrace 1: /lib/x86_64-linux-gnu/libc.so.6(+0x42520) [0x7efeeacdf520]]
07/21/24 09:18:59.809635 zmc_m1[50620].ERR-zm_signal.cpp/112 [Backtrace 2: /usr/bin/zmc(+0x76768) [0x56133920b768]]
07/21/24 09:18:59.809638 zmc_m1[50620].ERR-zm_signal.cpp/112 [Backtrace 3: /usr/bin/zmc(+0x47ce3) [0x5613391dcce3]]
07/21/24 09:18:59.809641 zmc_m1[50620].ERR-zm_signal.cpp/112 [Backtrace 4: /usr/bin/zmc(+0xfd9e1) [0x5613392929e1]]
07/21/24 09:18:59.809643 zmc_m1[50620].ERR-zm_signal.cpp/112 [Backtrace 5: /lib/x86_64-linux-gnu/libstdc++.so.6(+0xdc253) [0x7efeeb0ab253]]
07/21/24 09:18:59.809646 zmc_m1[50620].ERR-zm_signal.cpp/112 [Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(+0x94ac3) [0x7efeead31ac3]]
07/21/24 09:18:59.809648 zmc_m1[50620].ERR-zm_signal.cpp/112 [Backtrace 7: /lib/x86_64-linux-gnu/libc.so.6(+0x126850) [0x7efeeadc3850]]
07/21/24 09:18:59.809651 zmc_m1[50620].ERR-zm_signal.cpp/131 [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
07/21/24 09:18:59.809654 zmc_m1[50620].ERR-zm_signal.cpp/132 [and execute the following command for more information:]
07/21/24 09:18:59.809656 zmc_m1[50620].ERR-zm_signal.cpp/133 [addr2line -Cfip -e /usr/bin/zmc 0x8a4d9 0x76768 0x47ce3 0xfd9e1]
addr2line: DWARF error: unable to read alt ref 10615
addr2line: DWARF error: unable to read alt ref 49443
addr2line: DWARF error: could not find variable specification at offset 0xb79a
addr2line: DWARF error: could not find variable specification at offset 0xe85
addr2line: DWARF error: unable to read alt ref 254272
addr2line: DWARF error: unable to read alt ref 1166078
addr2line: DWARF error: could not find variable specification at offset 0xe6145
addr2line: DWARF error: could not find variable specification at offset 0x102f6
addr2line: DWARF error: could not find variable specification at offset 0x101f7
addr2line: DWARF error: unable to read alt ref 255667
addr2line: DWARF error: unable to read alt ref 129712
addr2line: DWARF error: unable to read alt ref 4205782
addr2line: DWARF error: unable to read alt ref 262983
addr2line: DWARF error: unable to read alt ref 261360
addr2line: DWARF error: unable to read alt ref 200949
addr2line: DWARF error: unable to read alt ref 1135358
addr2line: DWARF error: unable to read alt ref 1269
addr2line: DWARF error: unable to read alt ref 105558
addr2line: DWARF error: unable to read alt ref 169180
Monitor::Analyse() at ./dbuild/src/./src/zm_monitor.cpp:2551
Posted: Mon Jul 22, 2024 3:46 am
by asknight
Anna.N wrote: ↑Sun Jul 21, 2024 10:42 am
The relevant package is no longer in noble. Only jammy, and it complains loudly of tons of broken dependencies when it's tried to be forced.
https://ppa.launchpadcontent.net/iconnor/zoneminder-master/ubuntu/dists/noble/main/binary-amd64/
Posted: Mon Jul 22, 2024 8:43 am
by MarsRover
asknight wrote: ↑Mon Jul 22, 2024 3:46 am
You may look here, debs for last 8 builds are available
https://launchpad.net/~iconnor/+archive ... lter=noble
Posted: Tue Jul 23, 2024 1:35 pm
by asknight
MarsRover wrote: ↑Mon Jul 22, 2024 8:43 am
You are AWESOME and I can't thank you enough. I beat my keyboard to death the other night trying to locate that archive. It's now bookmarked in multiple locations, lol. Thanks again!
Posted: Tue Jul 23, 2024 8:59 pm
by MarsRover
I noticed that there's a new build 1.37.63~20240723103852 pushed to Ubuntu repo
Did anyone try it already, what about those segfaults, still there?
Posted: Wed Jul 24, 2024 6:49 am
by Anna.N
I tried zoneminder_1.37.63~20240723.45-bookworm. Seems to run without problems
Posted: Wed Jul 24, 2024 11:49 am
by hans109h
MarsRover wrote: ↑Tue Jul 23, 2024 8:59 pm
I tried this on 24.04 and still had the segmentation faults, I'm stable on the 20240716 version.
Hans
Posted: Thu Jul 25, 2024 2:21 pm
by bfl
1.37.63~20240723103852-jammy - no segfaults. Everything looks fine
