Cause - Continuous?
gbeyer
Cause - Continuous?
Post by gbeyer »
In the list of videos under Console, monitor name, almost all of my vids say in the "Cause" column "continuous" Nothing is happening when I play the vid. Does that mean it's recording continuously? I have motion detection zones setup. So I would think only motion would trigger a recording. How to I trigger a record only if there is motion? Thanks.
Andyrh
Re: Cause - Continuous?
Post by Andyrh »
The monitor function should be set to modect if you only want motion detection. If it set to record then you get the continuous.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
