Page 1 of 1
Cause - Continuous?
Posted: Thu Jul 25, 2024 10:12 pm
by gbeyer
In the list of videos under Console, monitor name, almost all of my vids say in the "Cause" column "continuous" Nothing is happening when I play the vid. Does that mean it's recording continuously? I have motion detection zones setup. So I would think only motion would trigger a recording. How to I trigger a record only if there is motion? Thanks.
Re: Cause - Continuous?
Posted: Fri Jul 26, 2024 12:37 pm
by Andyrh
The monitor function should be set to modect if you only want motion detection. If it set to record then you get the continuous.
