Page 1 of 1
filter throwing mySql syntax error
Posted: Fri Jul 26, 2024 1:42 pm
by aag
I have set up a filter to send me email alerts whenever a movement is detected. The movements are captured flawlessly, but the filter throws errors. Any idea how to fix this? See:
Can't execute filter 'SELECT E.*, unix_timestamp(E.StartDateTime) as Time
	FROM Events as E
	WHERE ( E.MaxScore >= 1 and E.AlarmFrames = ) AND ( E.Emailed = 0 )
	ORDER BY E.Id ASC LIMIT 0,100',
ignoring: You have an error in your SQL syntax;
check the manual that corresponds to your MySQL server version
for the right syntax to use near
') AND ( E.Emailed = 0 ) ORDER BY E.Id ASC LIMIT 0,100'
at line 4
Re: filter throwing mySql syntax error
Posted: Fri Jul 26, 2024 5:05 pm
by iconnor
Set a value for alarmframes?
Posted: Sat Jul 27, 2024 6:14 am
by aag
thanks, you are right and it's solved! It's a great software btw, I am totally impressed (even if I'm still struggling with all the features).
