Page 1 of 1
modify camera field of view
Posted: Mon Jul 29, 2024 9:13 pm
by 4bf9gSBj
many of my cameras have a 60 degree field of view
has anyone tried to add a second lens to increase the fov
Re: modify camera field of view
Posted: Tue Jul 30, 2024 12:30 am
by dougmccrary
Probably not. I add a second camera or replace it...
Posted: Tue Jul 30, 2024 12:39 am
by 4bf9gSBj
i see lots of clamp on lens for phone cameras
i may try some of those
new life for old hardware
Posted: Tue Jul 30, 2024 12:54 am
by dougmccrary
Could work, I guess. Let us know...
Posted: Tue Jul 30, 2024 5:25 pm
by mikb
4bf9gSBj wrote: ↑Mon Jul 29, 2024 9:13 pm
I have experimented with changing out the lens on a DCS900 (Dlink) to change the FOV, and also the colour/IR response.
Original lens is a colour one (does not do IR/night mode, there is an IR cut filter built in to lens).
I swapped one out for a slightly wider angle lens from a Maplin black/white security camera -- they were the same lens mount so simple unscrew/refit and refocus. This can now see in Infra Red (night use) at the expense of slightly odd colours in the day.
I think it's M12 x 0.5mm thread, same as a Go-Pro Hero/SJ4000/etc. action camera -- which has a very wide view (around 140-170' diagonal, super short focal lengths)
For another, to give it telephoto-zoom capability, I removed the stock lens entirely, leaving a bare sensor, and made a separate mount for a C/CS mount lens from a proper CCTV camera. Being designed for use with a larger sensor, the focal length of this is out of proportion to the tiny sensor in the DCS900, and bestows it with telephoto powers.
What you propose is possible -- depending on how much hacking you want to do! First job, get the exact spec of your existing lens (focal length, and thread type/mounting). Then you will know what you are looking for on e.g. eBay/Amazon for a replacement lens.
Posted: Tue Jul 30, 2024 7:41 pm
by rockedge
Very cool. Might be a whole new thing to experiment with...... the "retired" cameras laying around to find lens that will work on other cams.
Posted: Tue Jul 30, 2024 8:54 pm
by 4bf9gSBj
aliexpress has many sets of lens for phones
fisheye to long lens
