Home assistant zoneminder deleted cameras
You are running Zoneminder version 1.377.61 on debian linux.
My problem would be that if I integrate it into the home assistant in zoneminder, the cameras that have been deleted from zoneminder a long time ago also appear in the home assistant.
Deleted cameras cannot be deleted in the home assistant.
Can someone suggest how to disable zoneminder so that the deleted cameras are not transferred to the home assistant?
Re: Home assistant zoneminder deleted cameras
Deleted cameras are only marked deleted. You'll probably have to go into the "Monitors" db table and remove them.
See the wiki - MySQL for tips.
https://wiki.zoneminder.com/MySQL
I really ought to add some way to actually delete them.
