Hallo,
up to 1.36 the thumbnail was on the right side of the list and could be used to jump into the event. With 1.37 the thumbnail is on the left side. Now, when using a mobile browser in 'desktop mode' with a large virtual canvas you would need to move around a lot (left<>right) if you're mainly interested in the scores before entering an event. Another (optional) button/thumbnail on the right side would help here. The new layout is great on desktop systems but for small mobile browsers its kinda tricky.
'Event View List' - No possibility to enter event on the right side anymore
Re: 'Event View List' - No possibility to enter event on the right side anymore
As a quick solution, we can make more of the columns clickable.
There is a lot of work to do to make the UI more mobile friendly. One thing that I've played with converts the events table into a card view which is cool, but wouldn't happen in desktop mode.
Current build has diskspace and storage clickable.
Thanks, works great.
'Desktop mode' is a workaround only though. 'Mobile view' would be the preferred one if it wouldn't have the 'crop bug'. If setting 'Scale' to a large value it gets cropped at the left size. Together with the 'Old pan and zoom' mode (that is missing in event viewer) this mode would be on-par with 1.34.
When entering event view (on mobile mode) the 'video frame' is "zoomed-in" already (exceeding visible display area) so you can immediately move/pan around freely in the canvas during playback (no fiddling with positioning/resizing as in desktop mode). That's a quite comfortable way to watch videos in portrait mode.
The 'events table list' enables frame sliders (when having too many columns or entries) so you have two moving canvas (inner table and main page). That's kinda weird on touch screen as well. Maybe its possible to keep the sliders disabled.
If it doesn't blow up the line height everything's welcome.
Oh, that's card mode. Same as zmNinja. I rather prefer 'list view' though (high density informations). Card mode works but is barely visible if you do not maximize space for it (collapse filters, etc). As optional mode it might be useful i think.
