Overactive logging
MJN
Overactive logging
Post by MJN »
I have finally updated from 1.34.25 to 1.36.34 and beginning my journery discovering what changes there are. One thing I've noticed straight away is how wild the logging is, and by this I mean I am getting updates regarding each camera seemingly every second:
Aug 19 16:06:09 dellt20 zmc_m27[33088]: INF [zmc_m27] [Family Room (Low Res) (Revotech PIR): 260 - Capturing at 5.00 fps, capturing bandwidth 6597bytes/sec Analysing at 5.00 fps]
Aug 19 16:06:09 dellt20 zmc_m29[33100]: INF [zmc_m29] [Hall (Low Res) (Revotech PIR): 260 - Capturing at 5.00 fps, capturing bandwidth 4457bytes/sec Analysing at 5.00 fps]
Aug 19 16:06:09 dellt20 zmc_m25[33082]: INF [zmc_m25] [Doorbell (High Res) (Reolink D340W): 410 - Capturing at 8.20 fps, capturing bandwidth 725895bytes/sec Analysing at 0.00 fps]
Aug 19 16:06:09 dellt20 zmc_m28[33094]: INF [zmc_m28] [CatflapCam (Low Res) (Wansview K3 WiFi-Only): 260 - Capturing at 5.08 fps, capturing bandwidth 20051bytes/sec Analysing at 5.08 fps]
Aug 19 16:06:10 dellt20 zmc_m19[33205]: INF [zmc_m19] [Family Room (High Res) (Revotech PIR): 140 - Capturing at 5.00 fps, capturing bandwidth 116141bytes/sec Analysing at 0.00 fps]
Aug 19 16:06:10 dellt20 zmc_m15[33062]: INF [zmc_m15] [Patio (High Res) (Wansview W3): 270 - Capturing at 4.89 fps, capturing bandwidth 190545bytes/sec Analysing at 0.00 fps]
Aug 19 16:06:10 dellt20 zmc_m25[33082]: INF [zmc_m25] [Doorbell (High Res) (Reolink D340W): 420 - Capturing at 7.58 fps, capturing bandwidth 446957bytes/sec Analysing at 0.00 fps]
Aug 19 16:06:10 dellt20 zmc_m18[33067]: INF [zmc_m18] [Hall (High Res) (Revotech PIR): 270 - Capturing at 5.00 fps, capturing bandwidth 123355bytes/sec Analysing at 0.00 fps]
Aug 19 16:06:10 dellt20 zmc_m12[33057]: INF [zmc_m12] [SophieCam (Wansview K1): 270 - Capturing at 5.18 fps, capturing bandwidth 80341bytes/sec Analysing at 5.18 fps]
Aug 19 16:06:11 dellt20 zmc_m30[33106]: INF [zmc_m30] [Patio (Low Res) (Wansview W3): 270 - Capturing at 4.78 fps, capturing bandwidth 47606bytes/sec Analysing at 4.78 fps]
Aug 19 16:06:11 dellt20 zmc_m27[33088]: INF [zmc_m27] [Family Room (Low Res) (Revotech PIR): 270 - Capturing at 5.00 fps, capturing bandwidth 6547bytes/sec Analysing at 5.00 fps]
Aug 19 16:06:11 dellt20 zmc_m29[33100]: INF [zmc_m29] [Hall (Low Res) (Revotech PIR): 270 - Capturing at 5.00 fps, capturing bandwidth 4416bytes/sec Analysing at 5.00 fps]
Aug 19 16:06:11 dellt20 zmc_m28[33094]: INF [zmc_m28] [CatflapCam (Low Res) (Wansview K3 WiFi-Only): 270 - Capturing at 4.89 fps, capturing bandwidth 19363bytes/sec Analysing at 4.89 fps]
Aug 19 16:06:11 dellt20 zmc_m25[33082]: INF [zmc_m25] [Doorbell (High Res) (Reolink D340W): 430 - Capturing at 8.26 fps, capturing bandwidth 478880bytes/sec Analysing at 0.00 fps]
Aug 19 16:06:12 dellt20 zmc_m19[33205]: INF [zmc_m19] [Family Room (High Res) (Revotech PIR): 150 - Capturing at 5.00 fps, capturing bandwidth 116536bytes/sec Analysing at 0.00 fps]
Aug 19 16:06:12 dellt20 zmc_m15[33062]: INF [zmc_m15] [Patio (High Res) (Wansview W3): 280 - Capturing at 5.01 fps, capturing bandwidth 202050bytes/sec Analysing at 0.00 fps]
I have LOG_LEVEL_SYSLOG set to Info and the FPS Report Interval for all my cameras set to 10000 frames so as just to give me occasional (every half an hour or so) updates as to how each camera is performing. This used to result in a fairly quiet log but that is no longer the case!
MJN
Re: Overactive logging
Post by MJN »
Aha - found that this is a known issue/behaviour as per viewtopic.php?t=30902 and that it'll settle down once the first interval (10000 frames in my case) is reached.
