I'm having issues with the frontend since upgrade to 1.36.34. Please help. The issue appeared after the upgrade from 1.36.33.
Tried recreating the Mariadb DB, reconfigured almost everything from scratch, can't seem to find a solution. ZmNinja shows the same status issues.
The monitor starts showing warning "Monitor is not capturing. We will be unable to provide an image" after the first trigger is activated and the first recording finishes.
The whole backend - video recording, streaming everything continues to work flawlessly, meanwhile the frontend shows as if Monitor is not capturing and that modect isn't running. But it is working and it captures on motion detect end everything. It's driving me crazy, already spent 3 days trying to fix the issue but to no avail. Can't seem to figure this one out.
8/19/24, 2:29:39 PM GMT+2.009654 web_php[49618].WAR [*****Client_IP_Censored*****] [Unable to load Monitor status record for Id=1 using SELECT * FROM `Monitor_Status` WHERE `MonitorId`=?] at /usr/share/zoneminder/www/includes/Monitor.php line 208
8/19/24, 2:29:46 PM GMT+2.634108 web_php[49617].ERR [*****Client_IP_Censored*****] [socket_sendto( /run/zm/zms-096908s.sock ) failed: Connection refused] at /usr/share/zoneminder/www/includes/functions.php line 1884
I'm also geting quite a few alarms regarding the warning below, but this doesn't seem to actually have any impact from as far as I can tell:
08/19/24 18:39:50.091109 zmc_m1[448].WAR-zm_packetqueue.cpp/259 [Found iterator at beginning of queue. Some thread isn't keeping up]
$ zmupdate.pl
Database already at version 1.36.34, update skipped.
Linux zoneminder 5.15.0-118-generic #128-Ubuntu SMP Fri Jul 5 09:28:59 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
Server version: Apache/2.4.52 (Ubuntu)
Server built: 2024-07-17T18:57:26
PHP 8.1.2-1ubuntu2.18 (fpm-fcgi) (built: Jun 14 2024 15:52:55)
Copyright (c) The PHP Group
Zend Engine v4.1.2, Copyright (c) Zend Technologies
with Zend OPcache v8.1.2-1ubuntu2.18, Copyright (c), by Zend Technologies
Welcome to the MariaDB monitor. Your MariaDB connection id is 196
Server version: 10.6.18-MariaDB-0ubuntu0.22.04.1 Ubuntu 22.04Linux zoneminder 5.15.0-118-generic #128-Ubuntu SMP Fri Jul 5 09:28:59 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
ffmpeg version 4.4.2-0ubuntu0.22.04.1+esm1 Copyright (c) 2000-2021 the FFmpeg developers
built with gcc 11 (Ubuntu 11.3.0-1ubuntu1~22.04)
configuration: --prefix=/usr --extra-version=0ubuntu0.22.04.1+esm1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-librsvg --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil 56. 70.100 / 56. 70.100
libavcodec 58.134.100 / 58.134.100
libavformat 58. 76.100 / 58. 76.100
libavdevice 58. 13.100 / 58. 13.100
libavfilter 7.110.100 / 7.110.100
libswscale 5. 9.100 / 5. 9.100
libswresample 3. 9.100 / 3. 9.100
libpostproc 55. 9.100 / 55. 9.100
FFMPEG_OUTPUT_OPTIONS = -vf 'format=nv12|vaapi,hwupload'
