notify email recipient on error
alabamatoy
Post by alabamatoy »
Is there a way to make ZM send me an email when an error is encountered? I tried to write a filter and cant seem to find anything about error conditions.....
Re: notify email recipient on error
I use a program called logcheck to send me any errors that get logged to syslog. Then set ZM to log warnings to syslog. Works for me.
mikb
Post by mikb »
alabamatoy wrote: Sat Aug 31, 2024 3:27 pm when an error is encountered?
Can you be more specific on what kind of error/where the error is supposed to be coming from?
alabamatoy
mikb wrote: Sun Sep 01, 2024 4:16 pm
Im talking about an error that appears in the ZM log. Logcheck eventually sends me the entire log, 12 hours worth twice a day, but I was trying to get ZM (or something else) to notify me with an email message whenever a particular log event occurs within ZM. I would like to get an immediate notification for
8/28/24, 5:48:28 PM EDT	web_php	1189091	WAR	Login denied for user "XXXX"
while ignoring something like
9/2/24, 4:04:35 AM EDT	zmc_m4	1126489	ERR	Unable to open input rtsp://10.1.1.158:554/cam/realmonitor?channel=1&subtype=0 due to: Connection refused	zm_ffmpeg_camera.cpp	368
I see a flurry of these connection refused errors once in a while when the cameras restart etc but they only last a few seconds and go away. I have a user who has some issues with logins and passwords, and want to be alerted when he's having difficulty.
If logcheck can do this, I dont know how to configure it.
mikb
Post by mikb »
If there isn't a way to do that inside Zoneminder, then I'd be watching e.g. /var/log/zm/zm.log with a separate process, and watching for your key phrases to come up -- e.g. using "tail -f" to follow the end of the log and "grep -e 'Login denied for user' -e 'Another error' -e 'And Another error'" to pick off specific messages or reg-exps of messages.
burger
Post by burger »
Cron and grep works for me:
https://wiki.zoneminder.com/SMS_Notific ... _HDD_Fails
It's somewhat unfortunate to say that ZM needs monitoring scripts in order to run, as things are always breaking, but I don't know how it can be built into ZM without being more bloat. Maybe there can be optional shell scripts that are included in /usr/share/zoneminder. I've just made my own over time. Or you can use dedicated monitoring software but that has its own learning curve.
fastest way to test streams:
